| 0002417 | FreeCAD | Bug | public | 2016-01-23 13:27 | 2016-01-31 13:00 |
| Reporter | looo | Assigned To | wmayer | ||
| Priority | low | Severity | tweak | Reproducibility | always |
| Summary | 0002417: console autocomplete runs python properties | ||||
| Description | The FreeCAD console executes the properties of an object on autocomplete. | ||||
| Steps To Reproduce | run this macro: class a(object): @property def test1(self): print("hello") @property def test2(self): print(" you") Gui.object = a() and in console type: >>> Gui.object. this will trigger the properties. | ||||
The same also happens with old-style classes: class a: ... The commit 0f858f99 fixes this part of the problem. Instances of old-style classes can be easily identified by checking for PyInstance_Type. Then its type object (PyClass_Type) can be used to get all its attributes. However, I didn't find a way to identify instances or the types of new-style classes. Then, a "module" is also a new style class and to get all its attributes I must query the instance of the module and not its type object. Any idea how to solve this? |
I found a solution. To test for new-style classes the tp_flags is set to Py_TPFLAGS_HEAPTYPE and additionally I check that it's an instance of 'PyBaseObject_Type' (which corresponds to 'object' in Python). And the hasattr/getattr access has been replaced with a call of Py_CompileString & PyEval_EvalCode because otherwise a property is triggered twice. But note, when you enter 'Gui.object.test1.' into the console then test1 will be executed. I have tested this with the IDLE editor and this shows the same behaviour. |
FreeCAD: master 0f858f99 2016-01-31 02:28:24 Details Diff |
+ issue 0002417: console autocomplete runs python properties |
Affected Issues 0002417 |
| mod - src/Gui/CallTips.cpp | Diff File | ||
FreeCAD: master a3bf5421 2016-01-31 13:54:18 Details Diff |
+ fixes 0002417: console autocomplete runs python properties |
| 2016-01-23 13:27 | looo | New Issue | |
| 2016-01-31 01:28 | wmayer | Changeset attached | => FreeCAD Master master 0f858f99 |
| 2016-01-31 09:50 | wmayer | Note Added: 0006778 | |
| 2016-01-31 12:54 | wmayer | Changeset attached | => FreeCAD Master master a3bf5421 |
| 2016-01-31 12:54 | wmayer | Assigned To | => wmayer |
| 2016-01-31 12:54 | wmayer | Status | new => closed |
| 2016-01-31 12:54 | wmayer | Resolution | open => fixed |
| 2016-01-31 13:00 | wmayer | Note Added: 0006779 | |
| 2016-01-31 13:00 | wmayer | Fixed in Version | => 0.16 |
