| 0002422 | FreeCAD | Bug | public | 2016-01-27 09:16 | 2016-01-28 15:01 |
| Reporter | godshavethequeen | Assigned To | jmaustpc | ||
| OS Version | ubuntu 15.10 64b | ||||
| Summary | 0002422: fusion does not work | ||||
| Description | version 0.16 fusion between "cylinder" and "sweep" does not work | ||||
Please always post to the Help forum before making tickets. This is mostly user error. You have made one of the same most common mistakes with threads that has been posted about repeatedly including just a few days ago, rotate the Cylinder a few degrees. The Sweep was also not valid but a recompute fixed it for me so it could be many issues but most likely just that my software is more up to date than yours but I have to guess because you have not added your "Help menu... About FreeCAD" data. Please feel free to create a topic on the Help forum or better still read and post into this topic from a few days ago that explains much about this. http://forum.freecadweb.org/viewtopic.php?f=3&t=13949 Please also don't forget to add your Help about FreeCAD data if you do post to the forum. |
mostly user error, redirected to the Help forums. |
| 2016-01-27 09:16 | godshavethequeen | New Issue | |
| 2016-01-27 09:16 | godshavethequeen | File Added: filetmale.fcstd | |
| 2016-01-28 14:58 | jmaustpc | Note Added: 0006770 | |
| 2016-01-28 15:00 | jmaustpc | Note Edited: 0006770 | |
| 2016-01-28 15:01 | jmaustpc | Note Added: 0006771 | |
| 2016-01-28 15:01 | jmaustpc | Status | new => closed |
| 2016-01-28 15:01 | jmaustpc | Assigned To | => jmaustpc |
| 2016-01-28 15:01 | jmaustpc | Resolution | open => no change required |
