| 0002424 | FreeCAD | Bug | public | 2016-01-28 00:25 | 2016-02-02 21:26 |
| Reporter | CharlieMAC | Assigned To | yorik | ||
| Target Version | 0.16 | ||||
| Summary | 0002424: End arrow of lines in Draft have a wrong direction | ||||
| Description | When I try to create an arrow using the Draft WB and the "end arrow" property of the line object, the tip of the arrow has an incorrect direction. Normally, one expects that the tip of the line points outwards, but it turns out that it points inwards, from the end point to the start. Pleas note that this is NOT about dimensions. It's about the Draft line object and the "end arrow" property of it. | ||||
| Steps To Reproduce | 1.- Open FreeCAD 2.- Create a cylinder (optional) 3.- Load draft workbench 4.- Place the working plane on one of the faces (optional) 5.- Activate endpoint and center snapping (optional) 6.- Create a line from the center of the cylinder to the edge or elsewhere 7.- Toggle the end arrow property of the created line to true. The cylinder is actually not really necessary. It can be reproduced without it. | ||||
| Additional Information | OS: Debian GNU/Linux 8.3 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6263 (Git) Build type: Release Branch: master Hash: 2ed8e5dd995c76e85db0ea0d8b98ca861bf3834d Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
A link to the forum discussion. http://forum.freecadweb.org/viewtopic.php?f=3&t=14013 Obviously to see this one has to change from the default setting and turn off "Draft create Part objects where possible". Also you don't have to do the above all you have to do is create a Draft Line that is not running on the xy plane in only the x direction. I tried a few random orientations and they all had the arrow going in some different incorrect direction. OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6344 (Git) Build type: Debug Branch: master Hash: 2eb194776b8c69e64840e9f62a7cb66abdb8090a Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev |
Another related topic with some more related issues http://forum.freecadweb.org/viewtopic.php?f=3&t=14044 1) set a Draft Line to end arrow "arrow" and "true", create a new document copy paste that DLine into new document, These two Dline end arrow parameters get copied and displayed in the property editor but the arrow does not appear and a recompute does not help. If the "true/false" value is toggled an error message is produced because the coin object does not exist, when toggled back to true the default "Dot" arrow is displayed despite the "Arrow" value still being Arrow, so "Arrow" value must also be toggled. Coin error in SoGroup::removeChild(): tried to remove non-existent child 0x5915880 (Separator) 2) when "Hidden" is toggled the line itself toggles but the Arrow remain visible. |
There's one little last thing remaining. When a FreeCAD file is opened all the lines are visible but the arrows remain hidden. The property must be set to false and then again to true in order to show the arrows. OS: Debian GNU/Linux 8.3 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6378 (Git) Build type: Release Branch: master Hash: 388ea0629ca79f25bfea3445733232c7ab0c333f Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 |
true.. let's fix that... |
FreeCAD: master d45abca9 2016-01-30 17:31:32 Details Diff |
Draft: fixed end arrow of lines/wires - fixes 0002424 |
Affected Issues 0002424 |
FreeCAD: master ab89c9af 2016-02-02 22:26:34 Details Diff |
Draft: redraw wire arrow on file load - fixes 0002424 |
| 2016-01-28 00:25 | CharlieMAC | New Issue | |
| 2016-01-28 00:25 | CharlieMAC | File Added: Line.fcstd | |
| 2016-01-28 13:15 | jmaustpc | Note Added: 0006764 | |
| 2016-01-28 13:15 | jmaustpc | Assigned To | => yorik |
| 2016-01-28 13:15 | jmaustpc | Status | new => assigned |
| 2016-01-28 13:16 | jmaustpc | Product Version | => 0.16 |
| 2016-01-28 13:16 | jmaustpc | Target Version | => 0.16 |
| 2016-01-28 19:13 | yorik | Target Version | 0.16 => |
| 2016-01-29 06:06 | jmaustpc | Note Added: 0006775 | |
| 2016-01-29 16:23 | yorik | Target Version | => 0.16 |
| 2016-01-30 17:07 | yorik | Changeset attached | => FreeCAD Master master d45abca9 |
| 2016-01-30 17:07 | yorik | Status | assigned => closed |
| 2016-01-30 17:07 | yorik | Resolution | open => fixed |
| 2016-02-02 19:01 | CharlieMAC | Note Added: 0006797 | |
| 2016-02-02 19:01 | CharlieMAC | Status | closed => feedback |
| 2016-02-02 19:01 | CharlieMAC | Resolution | fixed => reopened |
| 2016-02-02 19:02 | CharlieMAC | Note Edited: 0006797 | |
| 2016-02-02 21:13 | yorik | Note Added: 0006798 | |
| 2016-02-02 21:26 | yorik | Changeset attached | => FreeCAD Master master ab89c9af |
| 2016-02-02 21:26 | yorik | Status | feedback => closed |
