0002435FreeCADBugpublic2016-02-07 06:55
Reportererskov Assigned Tojmaustpc
PlatformPCOSWindowsOS Version7
Summary0002435: When fillet outer edge the outer drawing disappears
DescriptionWhen use the fillet function on the drawing attach the outer drawing disappears.
This is tested on Freecad 0.16.6385
Steps To ReproduceTake the attach drawing do a fillet on the outer tube with the hole on 6 mm
an other problem
Do a fillet on the connection between the two tube, then the drawing is disappears
erskov
2016-02-04 09:24
reporter
ror-holder.FCStd (Attachment missing)
jmaustpc
2016-02-07 06:54
manager   ~0006814
with tangent edges like that you would expect problems with OCE.
Please always copy your full version information from the Help menu.... About FreeCAD dialogue from the Part or PartDesign workbench, you will get out put like this
OS: Ubuntu 12.04.5 LTS
Version: 0.16.6389 (Git)
Hash: 1867c0d276b4e3d7106e7eeaf08acd892ad1b850
Python version: 2.7.3
Qt version: 4.8.2
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18-dev
This would have been better posted to the Help forum as it is as much bad practice as a bug or at least a common limitation of many CAD kernels. Also the bug/limitation is in the CAD kernel OCE or OCC not actually FreeCAD.
Thank you for taking the time to create a ticket but please in the future first discuss only issues in the Help forum first to help keep the ticket quantity low and quality high.
jmaustpc
2016-02-07 06:55
manager   ~0006815
this is just a typical example of OCE fillet limitations with tangent edges.
2016-02-04 09:24 erskov New Issue
2016-02-04 09:24 erskov File Added: ror-holder.FCStd
2016-02-07 06:54 jmaustpc Note Added: 0006814
2016-02-07 06:55 jmaustpc Note Added: 0006815
2016-02-07 06:55 jmaustpc Status new => closed
2016-02-07 06:55 jmaustpc Assigned To => jmaustpc
2016-02-07 06:55 jmaustpc Resolution open => no change required
