| 0002440 | FreeCAD | Bug | public | 2016-02-07 15:51 | 2016-03-13 12:03 |
| Reporter | yoan | Assigned To | wmayer | ||
| Platform | Linux | OS | Mint 17 Qiana | OS Version | MATE 1.8.1 |
| Summary | 0002440: 0.16 Build rev 6395 Several display issues | ||||
| Description | * The new "Expression" window renders black * Renaming parts results in both old and new names overlapping (see screenshots) | ||||
OS: Linux Mint 17 Qiana Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6395 (Git) Build type: None Branch: master Hash: 1324575b3548d6730789baa453ad71fee35abe04 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
* The new "Expression" window renders black yes for me too I don't know if that is intentional or not. * Renaming parts results in both old and new names overlapping I don't see that when I edit the property or right click "rename", what exactly are you doing to get that result? Its better to discuss bugs you find on the Help forum first so the tickets are fewer in number and greater in quality, from more eyes seeing the matter. OS: Kubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6523 (Git) Build type: Release Branch: master Hash: ecd6517cb00fcf05edd41a38b3ce1fa8b16ec3ad Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18-dev |
The black part is supposed to be transparent. This might be a problem with the graphic driver. And the on-top widget is supposed to be positioned on the dialog so that the line fields are coincident. So, I don't think we can fix the actual problem. But alternatively, we can implement the on-top widget as another modal dialog without transparency and make an option in the preferences so that user with this issue have at least something properly working. |
> I don't see that when I edit the property or right click "rename", what exactly are you doing to get that result? I rename any object in the tree view, either via F2 or right click > rename > Its better to discuss bugs you find on the Help forum first so the tickets are fewer in number and greater in quality, from more eyes seeing the matter. Ok ! > and make an option in the preferences so that user with this issue have at least something properly working. Good idea! |
> The black part is supposed to be transparent. This might be a problem with the graphic driver. And the on-top widget is supposed to be positioned on the dialog so that the line fields are coincident. I have been using my Kubuntu 12.04 machine for a while which shows the black background, I read your comments so I checked on my Kubuntu 14.04 laptop which works as you say it should i.e not black surround. it is easy to read and works quite well with the black back ground so I wouldn't worry about it myself. I am assuming the update to 14.04 fixed my problem, the GPU is different still Nvidia nouveau. |
In order to solve the issue on your system: 1. Open the parameter editor and 2. navigate to the group BaseApp > Preferences > Expression (if 'Expression' doesn't exist you have to create it) 3. Create a boolean key called 'NoSystemBackground' and set it to 'false' That's it! Now reuse the expression editor and see that it's a normal dialog. |
| 2016-02-07 15:51 | yoan | New Issue | |
| 2016-02-07 15:51 | yoan | File Added: renaming_and_calcuation_window_bugs.png | |
| 2016-02-07 15:59 | yoan | Note Added: 0006816 | |
| 2016-03-01 15:45 | jmaustpc | Note Added: 0006873 | |
| 2016-03-01 15:46 | jmaustpc | Note Edited: 0006873 | |
| 2016-03-01 20:51 | wmayer | Note Added: 0006874 | |
| 2016-03-01 21:02 | yoan | Note Added: 0006875 | |
| 2016-03-01 21:57 | jmaustpc | Note Added: 0006876 | |
| 2016-03-13 11:58 | wmayer | Changeset attached | => FreeCAD Master master 18f0cc63 |
| 2016-03-13 12:03 | wmayer | Note Added: 0006905 | |
| 2016-03-13 12:03 | wmayer | Status | new => closed |
| 2016-03-13 12:03 | wmayer | Resolution | open => fixed |
| 2016-03-13 12:03 | wmayer | Product Version | => 0.16 |
| 2016-03-13 12:03 | wmayer | Fixed in Version | => 0.16 |
| 2016-03-13 12:03 | wmayer | Assigned To | => wmayer |
