| 0002442 | FreeCAD | Bug | public | 2016-02-07 20:44 | 2016-02-18 16:39 |
| Reporter | yoan | Assigned To | eivindkvedalen | ||
| Platform | Linux | OS | Linux Mint 17 Qiana | ||
| Summary | 0002442: FreeCAD 0.16: Expressions accross files are not saved | ||||
| Description | Expressions accross files other_file#Some_Part are saved as this_file#Some_Part when reopening the saved document. | ||||
| Steps To Reproduce | Open FreeCAD New document Select the "Part" workbench Draw a cube Save under cube.FCStd New document Select the "Part" workbench Draw a cylinder Set Cylinder.Radius to function cube#Cube.Height The cylinder has now a radius of 10mm (default height of a cube) Save under cylinder.FCStd Close FreeCAD Open FreeCAD Open cylinder.FCStd Checkout the value of Cylinder.Radius, it's now cylinder#Cube.Height instead of cube#Cube.Height | ||||
| Additional Information | OS: Linux Mint 17 Qiana Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6395 (Git) Build type: None Branch: master Hash: 1324575b3548d6730789baa453ad71fee35abe04 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Looks like it is properly saved but not restored, this line in ObjectIdentifier::resolve() overwrites the file reference provided by the file: documentName = String(doc->getName(), false, documentName.isForceIdentifier()); Although I don't get how these force identifiers work (ObjectIdentifier::documentObjectNameSet and ObjectIdentifier::String::forceIdentifier, aren't they the same parameters?) commenting this results in another uncaught exception so it seems more complex :) |
Please try the branch at https://github.com/eivindkv/free-cad-code/tree/Expressions_fixes_10 , and see if it solves your problem. |
Yes it works, thanks! Also when file_1 is opened and refers to file_2 that is not currently opened, any attempt to use a value file2#object.Property should raise "File file2 not opened" instead of Property not found. |
FreeCAD: master be671259 2016-02-12 22:13:58 Eivind Kvedalen Committer: wmayer Details Diff |
PropertExpressionEngine: Ignore dependencies that does not resolve to a document when verifying expressions. |
Affected Issues 0002442 |
| mod - src/App/PropertyExpressionEngine.cpp | Diff File | ||
FreeCAD: master 1da5d339 2016-02-12 22:24:41 Eivind Kvedalen Committer: wmayer Details Diff |
Expression class: Improved error message when resolving a variable fails. |
| mod - src/App/Expression.cpp | Diff File | ||
| mod - src/App/ObjectIdentifier.cpp | Diff File | ||
| mod - src/App/ObjectIdentifier.h | Diff File | ||
| 2016-02-07 20:44 | yoan | New Issue | |
| 2016-02-08 20:27 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2016-02-08 20:27 | eivindkvedalen | Status | new => assigned |
| 2016-02-10 22:03 | yoan | Note Added: 0006821 | |
| 2016-02-10 23:32 | eivindkvedalen | Note Added: 0006823 | |
| 2016-02-11 01:42 | yoan | Note Added: 0006824 | |
| 2016-02-18 16:39 | wmayer | Changeset attached | => FreeCAD Master master be671259 |
| 2016-02-18 16:39 | wmayer | Changeset attached | => FreeCAD Master master 1da5d339 |
| 2016-02-18 16:39 | wmayer | Status | assigned => closed |
| 2016-02-18 16:39 | wmayer | Resolution | open => fixed |
| 2016-02-18 16:39 | wmayer | Fixed in Version | => 0.16 |
