| 0002451 | FreeCAD | Bug | public | 2016-02-18 12:31 | 2016-02-20 09:20 |
| Reporter | s-light | Assigned To | |||
| Platform | 64bit | OS | Kubuntu | OS Version | 15.10 |
| Summary | 0002451: FreeCAD crashes on selecting Mirrowed Part | ||||
| Description | FreeCAD 0.16, Libs: 0.16R6431 (Git) (daily debs) with the appended FreeCAD file every time i open it and click on the mirrored part object - in the tree-view or in the 3D-view FreeCAD crashes. i have copied the log information from the terminal in the additional information field. | ||||
| Additional Information | stefan@stefan-latitude:~$ freecad FreeCAD 0.16, Libs: 0.16R6431 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## --accepting rule at line 275 ("Constraints") --accepting rule at line 149 ("[") --accepting rule at line 251 ("2") --(end of buffer or a NUL) --accepting rule at line 149 ("]") --(end of buffer or a NUL) --EOF (start condition 0) --accepting rule at line 158 ("-") --accepting rule at line 149 ("(") --accepting rule at line 248 ("10.3") --accepting rule at line 164 ("mm") --accepting rule at line 149 (")") --accepting rule at line 144 (" ") --accepting rule at line 149 ("/") --accepting rule at line 144 (" ") --(end of buffer or a NUL) --accepting rule at line 251 ("2") --(end of buffer or a NUL) --EOF (start condition 0) *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 stefan@stefan-latitude:~$ | ||||
| duplicate of | 0002389 | closed | eivindkvedalen | Crash systematic on the 10th sketch when employing a cavity. |
Which of the objects is the mirrored part object. I cannot find one. Nevertheless the bug looks similar to that in 0002436. Can you get the latest sources from master and check if this fixes the problem, please? |
I have added a screenshot where i hover the mirrored part with the mouse. in the treeview its 'Pin1_Sweep (Mirror #1)' my current version: OS: Ubuntu 15.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6433 (Git) Build type: None Branch: master Hash: 183f8dfebe92323c6bf4f0a378b062189eb95cae Python version: 2.7.10 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 (--> 2016/02/17 18:36:16) with this it chrashes if i click the highlighted object in the 3d view or click on the entry 'Pin1_Sweep (Mirror #1)' in the tree view. as soon as i can update i will try again. |
Maybe you have uploaded the wrong fcstd file. In the attached file there is definitely no object 'Pin1_Sweep (Mirror #1)' |
i have uploaded the file again. seems i have picked the backup file without the mirror... |
I have checked out git 69c241ba8972b which is the status before the fixes and this showed the crash exactly at the same position as 0002389. Going back to current master everything works properly again. |
| 2016-02-18 12:31 | s-light | New Issue | |
| 2016-02-18 12:31 | s-light | File Added: SDIP_4L.fcstd | |
| 2016-02-18 12:35 | s-light | File Added: FreeCAD.log | |
| 2016-02-18 16:47 | wmayer | Note Added: 0006834 | |
| 2016-02-19 11:06 | wmayer | Status | new => feedback |
| 2016-02-19 11:20 | s-light | File Added: FreeCAD_MirrorPart.png | |
| 2016-02-19 11:23 | s-light | Note Added: 0006835 | |
| 2016-02-19 11:23 | s-light | Status | feedback => new |
| 2016-02-19 14:20 | wmayer | Note Added: 0006836 | |
| 2016-02-19 14:20 | wmayer | Status | new => feedback |
| 2016-02-19 15:39 | s-light | File Added: SDIP_4L_CRASHES.fcstd | |
| 2016-02-19 15:40 | s-light | Note Added: 0006837 | |
| 2016-02-19 15:40 | s-light | Status | feedback => new |
| 2016-02-19 22:29 | wmayer | Relationship added | duplicate of 0002389 |
| 2016-02-20 09:20 | wmayer | Note Added: 0006838 | |
| 2016-02-20 09:20 | wmayer | Status | new => closed |
| 2016-02-20 09:20 | wmayer | Resolution | open => fixed |
| 2016-02-20 09:20 | wmayer | Fixed in Version | => 0.16 |
