| 0002456 | Draft | Bug | public | 2016-02-25 10:07 | 2016-02-26 19:12 |
| Reporter | Neutral | Assigned To | yorik | ||
| Platform | PC | OS | Windows | OS Version | Seven 64bit |
| Target Version | 0.16 | ||||
| Summary | 0002456: DWire undo bad behavior | ||||
| Description | When drafting a DWire shape, after having drawn more than 2 segments, the UNDO button doesn't undo the last segment but starts to erase the first segment (then second one and so on)... That renders this tool quite hard to use (no mistake allowed !) | ||||
| Steps To Reproduce | 1- New document 2- Select Draft mode 3- Select DWire tool 4- Set the working plane (e.g. XY) 5- Draw first segment (#1) 6- Draw segment 0000002 7- Draw segment 0000003 8- Click UNDO => The last segment is not erased but the first one... | ||||
| Additional Information | The Undo fucntion only erase the last segment if theere is no more than only 2 segments. | ||||
| 2016-02-25 10:07 | Neutral | New Issue | |
| 2016-02-25 19:19 | yorik | Assigned To | => yorik |
| 2016-02-25 19:19 | yorik | Status | new => assigned |
| 2016-02-25 19:20 | yorik | Note Added: 0006850 | |
| 2016-02-25 19:20 | yorik | Target Version | => 0.16 |
| 2016-02-26 19:12 | yorik | Changeset attached | => FreeCAD Master master d3870968 |
| 2016-02-26 19:12 | yorik | Status | assigned => closed |
| 2016-02-26 19:12 | yorik | Resolution | open => fixed |
