| 0000247 | FreeCAD | Bug | public | 2011-01-21 16:09 | 2011-01-26 14:13 |
| Reporter | frankkuester | Assigned To | |||
| Summary | 0000247: Crash on Windows with attached minimal file | ||||
| Description | FreeCAD reproducibly crashes when opening the attached file minimal.FCStd, selecting the object (a hollow cylinder) and selecting "Duplicate selection" in the menu. Windows wants to send a problem report to microsoft, and it's possible to view loads of info it wants to send. But it's not possible to copy that... Regards, Frank | ||||
| Additional Information | I'll try on Debian linux (squeeze) this Weekend or on Monday. | ||||
2011-01-21 16:09
(It's me, now with my private user name instead of the office one) On Debian squeeze (0.10.3225), I get the same crash. Here's the output in the terminal window that started freeCAD: $ FreeCAD 0.10, Libs: 0.10R3225 © Juergen Riegel, Werner Mayer 2001-2010 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Parameter not existing, write initial one This warning normally means that FreeCAD is running the first time or the configuration was deleted or moved. Build up the standard configuration. User settings not existing, write initial one This warning normally means that FreeCAD is running the first time or your configuration was deleted or moved. The system defaults will be reestablished for you. kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_klauncher.so Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString) kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_kded4.so kdeinit4: preparing to launch /usr/bin/kbuildsycoca4 kbuildsycoca4 running... kbuildsycoca4(13411) KBuildMimeTypeFactory::createEntry: Missing <comment> field in "audio/x-sbc.xml" kbuildsycoca4(13411) KBuildMimeTypeFactory::createEntry: Missing <comment> field in "application/x-hcidump.xml" kbuildsycoca4(13411) KConfigGroup::readXdgListEntry: List entry Categories in "/usr/share/applications/freecad.desktop" is not compliant with XDG standard (missing trailing semicolon). kbuildsycoca4(13411) KConfigGroup::readXdgListEntry: List entry MimeType in "/usr/share/applications/freecad.desktop" is not compliant with XDG standard (missing trailing semicolon). kbuildsycoca4(13411)/kdecore (services) KServicePrivate::init: The desktop entry file "/usr/share/applications/kde/kresources.desktop" has Type= "Application" but also has a X-KDE-Library key. This works for now, but makes user-preference handling difficult, so support for this might be removed at some point. Consider splitting it into two desktop files. kbuildsycoca4(13411) KConfigGroup::readXdgListEntry: List entry MimeType in "/usr/share/applications/wine.desktop" is not compliant with XDG standard (missing trailing semicolon). kbuildsycoca4(13411)/kdecore (services) KServicePrivate::init: The desktop entry file "/usr/share/applications/usbview.desktop" has Type= "Applications/System/Hardware" instead of "Application" or "Service" kbuildsycoca4(13411) KBuildServiceFactory::createEntry: Invalid Service : "/usr/share/applications/usbview.desktop" kbuildsycoca4(13411) KConfigGroup::readXdgListEntry: List entry MimeType in "/usr/share/applications/openoffice.org-startcenter.desktop" is not compliant with XDG standard (missing trailing semicolon). kbuildsycoca4(13411) KConfigGroup::readXdgListEntry: List entry Categories in "/usr/share/applications/jabref.desktop" is not compliant with XDG standard (missing trailing semicolon). kbuildsycoca4(13411) KConfigGroup::readXdgListEntry: List entry MimeType in "/usr/share/applications/jabref.desktop" is not compliant with XDG standard (missing trailing semicolon). kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_kconf_update.so Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString) kdeinit4: preparing to launch /usr/lib/kde4/libkdeinit/libkdeinit4_kconf_update.so kdeinit4: preparing to launch /usr/lib/kde4/kio_trash.so kdeinit4: preparing to launch /usr/lib/kde4/kio_file.so kio_trash(13417)/kdecore (services) KMimeTypeFactory::parseMagic: Now parsing "/usr/share/mime/magic" Illegal storage access... [1]+ Exit 3 freecad (539)[21:34:02]frank@riesling:~/EyeSense$ This was in fact the first time I started freeCAD on that computer. The second time, it looks like this, after the "User setting not existing" message: kdeinit4: preparing to launch /usr/lib/kde4/kio_trash.so kio_trash(13471)/kdecore (services) KMimeTypeFactory::parseMagic: Now parsing "/usr/share/mime/magic" Illegal storage access... The first two lines (kdeinit4 and kio_trash) appear when working with the file selection dialog. Regards, Frank |
I forgot: It's linux-2.6.26 on i686. The windows box is i686 and 32bit, too. |
I confirmed the problem on Windows 32 bit |
fixed in 3955 |
Just closing the item to make it disappear from the list |
| 2011-01-21 16:09 | frankkuester | New Issue | |
| 2011-01-21 16:09 | frankkuester | File Added: minimal.FCStd | |
| 2011-01-21 19:41 | kuesterei | Note Added: 0000544 | |
| 2011-01-21 19:42 | kuesterei | Note Added: 0000545 | |
| 2011-01-26 12:02 |
Note Added: 0000553 | |
| 2011-01-26 12:02 |
Status | new => confirmed |
| 2011-01-26 12:19 |
Note Added: 0000555 | |
| 2011-01-26 12:19 |
Status | confirmed => resolved |
| 2011-01-26 12:19 |
Fixed in Version | => 0.11 |
| 2011-01-26 12:19 |
Resolution | open => fixed |
| 2011-01-26 12:19 |
Assigned To | => Jriegel |
| 2011-01-26 14:13 | wmayer | Note Added: 0000557 | |
| 2011-01-26 14:13 | wmayer | Status | resolved => closed |
