0002481FreeCADBugpublic2016-03-20 17:54
Reportermascheck55 Assigned Toyorik
PlatformAMD 64bitOSWindowsOS Version8.1
Product Version0.15
Summary0002481: Geo Data feature does not run
Descriptionthe macro wants to import geodat.kthread and fails
Steps To ReproduceGui.activateWorkbench("Geodat")
and the reportview:
run import ...
Running the Python command 'Import OSM Map' failed:
  File "<string>", line 81, in Activated
  File "C:\Users\Andreas\AppData\Roaming\FreeCAD\Mod\geodata\geodat\__init__.py", line 4, in <module>
No module named kthread
yorik
2016-03-20 17:54
administrator   ~0006917
Macro and external workbench authors don't use this tracker. You'd better report directly on the issue tracker of the specific macro or workbench...
2016-03-19 19:09 mascheck55 New Issue
2016-03-20 17:54 yorik Note Added: 0006917
2016-03-20 17:54 yorik Status new => closed
2016-03-20 17:54 yorik Assigned To => yorik
2016-03-20 17:54 yorik Resolution open => no change required
