| 0002483 | FreeCAD | Bug | public | 2016-03-22 15:08 | 2016-04-06 10:27 |
| Reporter | brickZA | Assigned To | eivindkvedalen | ||
| Summary | 0002483: Undo in spreadsheet breaks alias linkage | ||||
| Description | If I have a value in a spreadsheet cell that is linked to geometry via an alias, editing the value in the spreadsheet immediately updates the model as expected. If I "undo" in the spreadsheet, the value goes back to as before. However, the model does not update back to the original. Editing the value in the spreadsheet again also does not cause the model to update. If I save the model at that stage and re-open, all the spreadsheet cell aliases have disappeared. Re-configuring the alias with the same names as before restores the linkage to the model. | ||||
| Steps To Reproduce | 1. Open attached fcstd file. 2. Double click on Spreadsheet in tree 3. Edit one of the value cells (model should update) 4. Undo (value change is undone in Spreadsheet, but model does not update) 5. Save 6. Close FreeCAD and re-open file 7. Double click on Spreadsheet 8. Right-click on any of the value cells and check their Alias, now empty. | ||||
| Additional Information | Using daily build from https://launchpad.net/~freecad-maintainers/+archive/ubuntu/freecad-daily OS: Ubuntu 15.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6647 (Git) Build type: None Branch: master Hash: 9299a73cf1482db4120b94543b33c2f9ec758319 Python version: 2.7.10 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Forgot to add to be bug report? Nothing in the "Report" window, nothing logged to console and apparently nothing interesing in FreeCAD.log (see attachment) |
Recreated problem in current master. |
FreeCAD: master 8fe0d424 2016-04-04 19:57:25 Eivind Kvedalen Details Diff |
Spreadsheet: Fixed undo/redo (issue 0002483). |
Affected Issues 0002483 |
| mod - src/Mod/Spreadsheet/App/Cell.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/App/Cell.h | Diff File | ||
| mod - src/Mod/Spreadsheet/App/PropertySheet.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SpreadsheetView.cpp | Diff File | ||
| 2016-03-22 15:08 | brickZA | New Issue | |
| 2016-03-22 15:08 | brickZA | File Added: kombuislaaikas.fcstd | |
| 2016-03-22 15:11 | brickZA | Note Added: 0006930 | |
| 2016-03-22 15:11 | brickZA | File Added: FreeCAD.log | |
| 2016-04-02 09:31 | eivindkvedalen | Note Added: 0006942 | |
| 2016-04-02 09:31 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2016-04-02 09:31 | eivindkvedalen | Status | new => confirmed |
| 2016-04-02 09:32 | eivindkvedalen | Status | confirmed => assigned |
| 2016-04-06 10:25 | Changeset attached | => FreeCAD Master master 8fe0d424 | |
| 2016-04-06 10:27 | wmayer | Status | assigned => closed |
| 2016-04-06 10:27 | wmayer | Resolution | open => fixed |
| 2016-04-06 10:27 | wmayer | Fixed in Version | => 0.16 |
