| 0002487 | Draft | Bug | public | 2016-03-31 14:47 | 2016-04-28 20:10 |
| Reporter | r-frank | Assigned To | yorik | ||
| Platform | Linux | OS | Linux Mint | OS Version | 17 - Qiana |
| Summary | 0002487: Nearest snaps not to intersect | ||||
| Description | When selecting snap "nearest" intersection of two draft lines is not recognized. On Windows that works ... | ||||
| Steps To Reproduce | Look at this thread for more information: http://forum.freecad.org/viewtopic.php?f=3&t=15050 | ||||
Why would intersections be recognized by the nearest snap? Isn't it intersection snapping that you need? |
Intersections (and endpoint snaps) as nearest snaps are recognized on Windows and they AREN'T on Linux. At least that should be made the same behaviour ? I'm talking about nearest snaps behaving completely different on different platforms ... (OK, maybe it's more an enhancement request than a real bug report ...) |
I don't have a windows machine to test unfortunately, but I can't find anything in the code that would produce a different result on windows and linux... could it be because your snap range value is different? (Tools -> Parameters -> Mod -> Draft -> snapRange) |
I just verified with 0.16.6700 on Windows 7 64-bit and 0.16.6698 on Linux Mint 17. In both FreeCAD's NO snaprange is set. BUT now both versions work the same way with intersection snap and with nearest snap. So maybe your small fix did the trick or it was another commit. Anyway, thanks for looking into this matter. We can consider the case closed. Have a nice day. |
Yeah, the problem probably got fixed without wanting... Okay then, closing it! |
| 2016-03-31 14:47 | r-frank | New Issue | |
| 2016-03-31 22:32 | yorik | Note Added: 0006940 | |
| 2016-03-31 22:34 | yorik | Changeset attached | => FreeCAD Master master f526ff8f |
| 2016-04-01 17:54 | r-frank | Note Added: 0006941 | |
| 2016-04-26 22:56 | yorik | Note Added: 0007010 | |
| 2016-04-26 22:56 | yorik | Assigned To | => yorik |
| 2016-04-26 22:56 | yorik | Status | new => feedback |
| 2016-04-28 20:02 | r-frank | Note Added: 0007023 | |
| 2016-04-28 20:02 | r-frank | Status | feedback => assigned |
| 2016-04-28 20:10 | yorik | Note Added: 0007024 | |
| 2016-04-28 20:10 | yorik | Status | assigned => closed |
| 2016-04-28 20:10 | yorik | Resolution | open => fixed |
| 2016-04-28 20:10 | yorik | Fixed in Version | => 0.16 |
