| 0002489 | Sketcher | Bug | public | 2016-04-03 04:48 | 2016-10-15 19:48 |
| Reporter | mimosa | Assigned To | normandc | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| Platform | PC | OS | Windows | OS Version | 10 |
| Summary | 0002489: Sketch inverts itself | ||||
| Description | The sketch is a little buggy, or something happen after 2 or 3 pads/pockets have been created (each with their own sketches, some sketch on plane from a pad), let say: 1) Create sketch01 (on a global plane), done. Create pad01 from sketch01 2) Create sketch02 (on a plane from one of the pad01 surface), done. Create pocket01 from sketch02 2) Create sketch03 (on a plane from one of the pocket01 result), done. Create pocket02 from sketch03 now edit pad01 (thickness or whatever) and sketch02 has an inverted vertical axis in its sketch, that is, the sketch is now outside the pad.. buggy! | ||||
| Steps To Reproduce | Read description | ||||
This bug report is useless without a case file. Please also provide your full FreeCAD info as explained here: http://forum.freecadweb.org/viewtopic.php?f=3&t=2264 0.16 is about to come out, it is useless to report bugs on 0.15. And please, read the bug submission guidelines before posting anymore reports. http://forum.freecadweb.org/viewtopic.php?f=3&t=5236 |
No further information was supplied by original poster, I'm closing this bug report. |
| 2016-04-03 04:48 | mimosa | New Issue | |
| 2016-04-05 00:37 | normandc | Note Added: 0006947 | |
| 2016-10-15 19:48 | normandc | Note Added: 0007368 | |
| 2016-10-15 19:48 | normandc | Status | new => closed |
| 2016-10-15 19:48 | normandc | Assigned To | => normandc |
| 2016-10-15 19:48 | normandc | Resolution | open => won't fix |
