| 0000250 | FreeCAD | Bug | public | 2011-01-24 10:05 | 2015-01-06 11:26 |
| Reporter | myier | Assigned To | |||
| Summary | 0000250: Rendering window is not sized to the size of the main window when creating a new document with Windows OS. | ||||
| Description | I just installed 3915 windows 32bit version, and when I create a new document after FreeCAD has started, the created (blue rendering) window is smaller that the main window. I have to resize the main window to have it updated to the big size. | ||||
Can you add a screenshot. please. I'm not if I got you right but it again can be a OpenGL problem. |
2011-01-25 17:38
Done. Look at the bottom and the right of the rendering. |
I guess this is a further problem with your OpenGL driver. Anybody else out there who has the same problem but with a functioning driver? |
Mhh, thats an extreme Monitor resolution. I think you need a dual port display for that (DVI can only do 1900x1200 as I know). Looks for me the Gl driver can not open a Window that big... |
The size of the window is just a problem on initialization, if I resize it manually, the rendering is automatically extented to the full size of the window. And it is properly rendered, so I guess it means the GL is working. But you're right, the card needs two gpu to display it I think, although there is only one DVI cable connected to it. |
Is this still an issue? |
Yes. Same thing, when I resize the window the blue panel gets maximized in the window. That's not important and probably related to my lame graphic setup. |
I have here a monitor of almost the same resolution: 2560x1440 and there it works as expected. So, it is related to your driver and I close this ticket as "not fixable". |
| 2011-01-24 10:05 | myier | New Issue | |
| 2011-01-25 12:28 | wmayer | Note Added: 0000547 | |
| 2011-01-25 17:38 | myier | File Added: FreeCAD_windows_problem.png | |
| 2011-01-25 17:39 | myier | Note Added: 0000548 | |
| 2011-01-25 21:24 | wmayer | Note Added: 0000549 | |
| 2011-01-26 11:13 |
Note Added: 0000550 | |
| 2011-01-26 17:28 | myier | Note Added: 0000558 | |
| 2011-11-24 01:13 | yorik | Note Added: 0001347 | |
| 2011-11-24 01:13 | yorik | Status | new => feedback |
| 2011-11-28 10:41 | myier | Note Added: 0001367 | |
| 2015-01-06 11:26 | wmayer | Note Added: 0005532 | |
| 2015-01-06 11:26 | wmayer | Status | feedback => closed |
| 2015-01-06 11:26 | wmayer | Resolution | open => not fixable |
