| 0002502 | PartDesign | Feature | public | 2016-04-14 10:08 | 2016-10-23 23:50 |
| Summary | 0002502: Inconsistent selection | ||||
| Description | When creating a sketch and you select a base plane in the 3d view it selects the item in the dialog. But the other way around it doesn't work, i.e. when selecting the item in the dialog it doesn't select the base plane in the 3d view. It would be nice to support this because it gives an indication to the user where the sketch will be placed. | ||||
| 2016-04-14 10:08 | wmayer | New Issue | |
| 2016-04-14 10:08 | wmayer | Status | new => assigned |
| 2016-04-14 10:08 | wmayer | Assigned To | => ickby |
| 2016-04-14 11:44 | ickby | Note Added: 0006965 | |
| 2016-04-14 11:44 | ickby | Status | assigned => confirmed |
| 2016-10-23 23:50 | wmayer | Changeset attached | => FreeCAD Master master 9c113494 |
| 2016-10-23 23:50 | wmayer | Assigned To | ickby => wmayer |
| 2016-10-23 23:50 | wmayer | Status | confirmed => closed |
| 2016-10-23 23:50 | wmayer | Resolution | open => fixed |
