| 0002521 | FreeCAD | Bug | public | 2016-04-24 18:46 | 2016-05-20 11:13 |
| Reporter | berka | Assigned To | wmayer | ||
| Platform | x86_64 | OS | Mac OS | OS Version | 10.11.4 (15E65) |
| Summary | 0002521: SIGSEGV when trying to revert to saved file. | ||||
| Description | FreeCAD crashes when selecting File->Revert and confirming the dialog box. When invoked from the command line the following is the output: ############################# $ /Applications/3D\ CAD/FreeCAD.app/Contents/bin/FreeCAD -l FreeCAD 0.16, Libs: 0.16R6702 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly. 2016-04-24 14:34:57.592 FreeCAD[19352:4117876] modalSession has been exited prematurely - check for a reentrant call to endModalSession: *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 | ||||
| Steps To Reproduce | 1) Open FreeCAD 2) Open an existing project 3) Optional: Make changes to project. 4) Select Menu item File->Revert 5) Answer "Yes" to the "Are you sure" dialog box. | ||||
| Additional Information | OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6702 (Git) Build type: Release Branch: (detached from d2a08df) Hash: d2a08df5e2db1c9c1dfa39dd45f1a306b3955cdc Python version: 2.7.11 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 | ||||
Could you offer the stack trace of the crash, please? |
This crash doesn't generate the diagnostic information I'm accustomed to seeing when an application crashes. I scraped through MacOS logs at various places for 30 minutes for any indication, but I can't find anything. The other FreeCAD references are to some stack sampling done when FreeCAD becomes unresponsive for a few seconds here and there. Any ideas? |
You have to explicitly run FreeCAD in the debugger (is it lldb on OSX?) and then wait for the crash to be happen. Afterwards you should be able to get the stack information with "bt". Doesn't this work this way? |
Hi. Sorry this took so long. You're right lldb allowed me to halt on exception and run a backtrace. I will attach. I normally get this (and more) information automatically reported on an application crash. This is very easy to reproduce, so let me know if you need any experiments done. |
Thanks for the information. It shows the relevant part of the call stack so I hope we can reproduce it, too. |
I have applied this fix to v0.16, too. |
FreeCAD: master 2e79aefc 2016-05-20 13:01:23 Details Diff |
+ issue 0002521: SIGSEGV when trying to revert to saved file. |
Affected Issues 0002521 |
| mod - src/App/Document.cpp | Diff File | ||
FreeCAD: releases 0c449d7e 2016-05-20 13:11:46 Details Diff |
| 2016-04-24 18:46 | berka | New Issue | |
| 2016-04-25 08:03 | wmayer | Note Added: 0007001 | |
| 2016-04-25 08:03 | wmayer | Status | new => feedback |
| 2016-04-25 08:50 | berka | Note Added: 0007002 | |
| 2016-04-25 08:50 | berka | Status | feedback => new |
| 2016-04-25 09:35 | wmayer | Note Added: 0007003 | |
| 2016-05-20 08:28 | berka | Note Added: 0007113 | |
| 2016-05-20 08:31 | berka | File Added: FreecadStack-Bug0002521.txt | |
| 2016-05-20 08:54 | wmayer | Note Added: 0007114 | |
| 2016-05-20 10:16 | wmayer | Assigned To | => wmayer |
| 2016-05-20 10:16 | wmayer | Status | new => confirmed |
| 2016-05-20 11:03 | wmayer | Changeset attached | => FreeCAD Master master 2e79aefc |
| 2016-05-20 11:12 | wmayer | Changeset attached | => FreeCAD Master releases 0c449d7e |
| 2016-05-20 11:13 | wmayer | Note Added: 0007115 | |
| 2016-05-20 11:13 | wmayer | Status | confirmed => closed |
| 2016-05-20 11:13 | wmayer | Resolution | open => fixed |
| 2016-05-20 11:13 | wmayer | Fixed in Version | => 0.16 |
