| 0002524 | FreeCAD | Feature | public | 2016-04-26 22:36 | 2016-10-08 01:21 |
| Summary | 0002524: Make property docstrings translatable | ||||
| Description | Upgrade FeaturePython::addProperty method to support unicode | ||||
| Additional Information | http://forum.freecadweb.org/viewtopic.php?f=3&t=14914 | ||||
I now changed the strategy: It is wrong to translate the properties docstrings when adding properties to features. Because by doing that, the translated string is written into the file, so a user from another country could open a file and get a property whose docstring is in an ununderstandable language. A much better way would be to use the same system as for commands (QtCore.QT_TRANSLATE_NOOP) and have the property docstring translated when showing it in the FreeCAD interface only. For now, I removed all docstring translations, which will solve the errors mentioned in the linked topic. |
Important for this to work is that the context string used for QT_TRANSLATE_NOOP is everywhere the same because the property editor has no knowledge where the strings come from. What about using "CustomProperty" as context? |
Yes I was thinking about that too... or "PropertyDescription" |
I think PropertyDescription is a bit long and is too tight with the doc string. One could also think about making the group name translatable. Therefore I chose the prefix "App::Property". |
Wow, thanks a lot! I would have taken a lot of time to find out how to do it... I'll keep this opened until I added the QT_TRANSLATE_NOOP in python scripts |
FreeCAD: master e6dd3488 2016-05-18 21:59:15 Details Diff |
removed translation from property descriptions (wrong to do it there anyway) - issue 0002524 |
Affected Issues 0002524 |
| mod - src/Mod/Arch/ArchAxis.py | Diff File | ||
| mod - src/Mod/Arch/ArchBuilding.py | Diff File | ||
| mod - src/Mod/Arch/ArchComponent.py | Diff File | ||
| mod - src/Mod/Arch/ArchEquipment.py | Diff File | ||
| mod - src/Mod/Arch/ArchFloor.py | Diff File | ||
| mod - src/Mod/Arch/ArchPanel.py | Diff File | ||
| mod - src/Mod/Arch/ArchRoof.py | Diff File | ||
| mod - src/Mod/Arch/ArchSectionPlane.py | Diff File | ||
| mod - src/Mod/Arch/ArchSite.py | Diff File | ||
| mod - src/Mod/Arch/ArchSpace.py | Diff File | ||
| mod - src/Mod/Arch/ArchStairs.py | Diff File | ||
| mod - src/Mod/Arch/ArchStructure.py | Diff File | ||
| mod - src/Mod/Arch/ArchWall.py | Diff File | ||
| mod - src/Mod/Arch/ArchWindow.py | Diff File | ||
| mod - src/Mod/Fem/_ViewProviderFemAnalysis.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathComment.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathCompoundExtended.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathCopy.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathDressup.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathDrilling.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathFixture.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathFromShape.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathHop.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathKurve.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathLoadTool.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathMachine.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPlane.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPocket.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathProfile.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathProject.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathStock.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathStop.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathToolLenOffset.py | Diff File | ||
FreeCAD: master 61f663d1 2016-09-08 18:29:27 Details Diff |
issue 0002524: Make property docstrings translatable |
| mod - src/Gui/ViewProviderOrigin.cpp | Diff File | ||
| mod - src/Gui/ViewProviderOriginFeature.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.cpp | Diff File | ||
FreeCAD: master dabccc40 2016-10-08 02:37:15 Details Diff |
Made Arch objects properties translatable - issue 0002524 |
| mod - src/Mod/Arch/ArchFrame.py | Diff File | ||
| mod - src/Mod/Arch/ArchPipe.py | Diff File | ||
| mod - src/Mod/Arch/ArchPrecast.py | Diff File | ||
| mod - src/Mod/Arch/ArchProfile.py | Diff File | ||
| mod - src/Mod/Arch/ArchRebar.py | Diff File | ||
| mod - src/Mod/Arch/ArchSchedule.py | Diff File | ||
| mod - src/Mod/Arch/ArchServer.py | Diff File | ||
| mod - src/Mod/Arch/InitGui.py | Diff File | ||
FreeCAD: master 17a24a4b 2016-10-08 02:55:26 Details Diff |
Made Draft objects properties translatable - issue 0002524 |
FreeCAD: master a50bd5dc 2016-10-08 03:21:02 Details Diff |
Made Path objects properties translatable - fixes 0002524 |
| mod - src/Mod/Path/PathScripts/DragknifeDressup.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathArray.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathCustom.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathEngrave.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathFacePocket.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathFaceProfile.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathRemote.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathSurface.py | Diff File | ||
| 2016-04-26 22:36 | yorik | New Issue | |
| 2016-04-26 22:36 | yorik | Status | new => assigned |
| 2016-04-26 22:36 | yorik | Assigned To | => yorik |
| 2016-05-18 19:59 | yorik | Changeset attached | => FreeCAD Master master e6dd3488 |
| 2016-05-18 20:03 | yorik | Note Added: 0007112 | |
| 2016-05-18 20:03 | yorik | Summary | Add unicode support to FeaturePython::AddProperty => Make property docstrings translatable |
| 2016-05-18 20:04 | yorik | Note Edited: 0007112 | |
| 2016-09-08 08:38 | wmayer | Note Added: 0007310 | |
| 2016-09-08 14:02 | yorik | Note Added: 0007311 | |
| 2016-09-08 16:30 | wmayer | Changeset attached | => FreeCAD Master master 61f663d1 |
| 2016-09-08 16:33 | wmayer | Note Added: 0007312 | |
| 2016-09-08 19:39 | yorik | Note Added: 0007313 | |
| 2016-10-08 01:21 | yorik | Changeset attached | => FreeCAD Master master dabccc40 |
| 2016-10-08 01:21 | yorik | Changeset attached | => FreeCAD Master master 17a24a4b |
| 2016-10-08 01:21 | yorik | Changeset attached | => FreeCAD Master master a50bd5dc |
| 2016-10-08 01:21 | yorik | Status | assigned => closed |
| 2016-10-08 01:21 | yorik | Resolution | open => fixed |
