| 0002525 | FreeCAD | Bug | public | 2016-04-27 06:54 | 2016-05-13 03:58 |
| Reporter | revolver1941 | Assigned To | wmayer | ||
| Platform | Intel 64-bit | OS | Windows | OS Version | 10 |
| Summary | 0002525: Line color of shapes are always black | ||||
| Description | All the Line Color of shapes always turns into black when re-open a .FCStd file only by version 0.17. A topic in forum http://forum.freecadweb.org/viewtopic.php?f=8&t=15475 | ||||
| Steps To Reproduce | Run FreeCAD. Switch to part workbench. Create a cube or something others. Set the cube's Line Color into any color except black. Save the .FCStd document. Close FreeCAD. Run FreeCAD again. Open the previous saved .FCStd document. Then you found the cube's Line Color turns into black although the property value has not changed. | ||||
OS: Windows 8 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7447 (Git) Build type: Release Branch: master Hash: 898bd8bb4cbe2c9b26aa6c1f7362e48752a3e4de Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
A new property "LineColorArray" has been introduced to allow to set individual colors for the edges. However, the two properties are not synchronized so that the reading of the LineColorArray overwrites the correct colors again. For the moment it must made sure to synchronize the properties. In the long term it's best to have only one property and remove the others. Responsible commit: https://github.com/FreeCAD/FreeCAD/commit/af25c0c7939aa04616dbfd0a220a42d159c67326 |
Note to myself: Implement the class PropertyMaterialList and use this for vertex, edge and face colors. |
The actual issue has been resolved now. But note since projects created with 0.17 contain the inconsistent colors the lines will still be black. You first have to fix the colors and save the file again. Afterwards the load works as expected. I leave this ticket open because for the long-term solution still a lot of things must be implemented. |
FreeCAD: master 7e01d012 2016-05-06 13:57:13 Details Diff |
+ issue 0002525: Line color of shapes are always black |
Affected Issues 0002525 |
| mod - src/Mod/Part/Gui/ViewProviderExt.cpp | Diff File | ||
FreeCAD: master 317b447f 2016-05-07 14:41:24 Details Diff |
+ implement PropertyMaterialList |
| mod - src/App/FeatureTest.cpp | Diff File | ||
| mod - src/App/FeatureTest.h | Diff File | ||
| mod - src/App/PropertyStandard.cpp | Diff File | ||
| mod - src/App/PropertyStandard.h | Diff File | ||
FreeCAD: master 8bbc6421 2016-05-07 22:11:37 Details Diff |
+ editor for PropertyMaterial |
| mod - src/Gui/SoFCDB.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.h | Diff File | ||
| 2016-04-27 06:54 | revolver1941 | New Issue | |
| 2016-04-27 06:54 | revolver1941 | File Added: 4.PNG | |
| 2016-04-27 06:57 | revolver1941 | Note Added: 0007011 | |
| 2016-04-27 06:57 | revolver1941 | File Added: 3.PNG | |
| 2016-05-06 09:01 | wmayer | Note Added: 0007054 | |
| 2016-05-06 09:01 | wmayer | Assigned To | => wmayer |
| 2016-05-06 09:01 | wmayer | Status | new => confirmed |
| 2016-05-06 10:18 | wmayer | Note Added: 0007056 | |
| 2016-05-06 11:57 | wmayer | Changeset attached | => FreeCAD Master master 7e01d012 |
| 2016-05-06 12:00 | wmayer | Note Added: 0007061 | |
| 2016-05-06 12:00 | wmayer | Status | confirmed => resolved |
| 2016-05-06 12:00 | wmayer | Fixed in Version | => 0.17 |
| 2016-05-06 12:00 | wmayer | Resolution | open => fixed |
| 2016-05-07 12:42 | wmayer | Changeset attached | => FreeCAD Master master 317b447f |
| 2016-05-07 21:25 | wmayer | Changeset attached | => FreeCAD Master master 8bbc6421 |
| 2016-05-13 03:58 | yorik | Status | resolved => closed |
