| 0002528 | Path | Feature | public | 2016-04-28 10:22 | 2016-07-27 00:37 |
| Reporter | ghislainvdwalle | Assigned To | sliptonic | ||
| Platform | all | OS | all | OS Version | Win7, Debian |
| Summary | 0002528: G-Code output | ||||
| Description | Referring to the Cutter compensation topic discussed with Sliptonic 26/04, there is a concensus that in the output G-Code file should be a comment referring to the offset tool. like for LinuxCNC: (Cutter Compensated Path End Mill 10mm) G0 X100.0 Y50.0 ... ... G0 Z100.0 (End Cutter Compensated Path End Mill 10mm) This would prevent the operator of using the incorrect tool on the machine. Working on a mold means having a lot of G-Code files. This improvement should allow a better oversight. | ||||
| Steps To Reproduce | - | ||||
| Additional Information | - | ||||
FreeCAD: master d1b92776 2016-07-03 17:27:12 Committer: yorik Details Diff |
Fix for bug 0002528 Improved handling of comments |
Affected Issues 0002528 |
| mod - src/Mod/Path/PathScripts/PathLoadTool.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathMachine.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPocket.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathProfile.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathSurface.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/dumper_post.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/example_post.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/linuxcnc_post.py | Diff File | ||
| 2016-04-28 10:22 | ghislainvdwalle | New Issue | |
| 2016-07-03 15:08 | sliptonic | Assigned To | => sliptonic |
| 2016-07-03 15:08 | sliptonic | Status | new => assigned |
| 2016-07-03 17:12 | sliptonic | Note Added: 0007171 | |
| 2016-07-03 17:12 | sliptonic | Status | assigned => resolved |
| 2016-07-03 17:12 | sliptonic | Resolution | open => fixed |
| 2016-07-04 01:43 | yorik | Changeset attached | => FreeCAD Master master d1b92776 |
| 2016-07-27 00:37 | yorik | Status | resolved => closed |
| 2016-07-27 00:37 | yorik | Fixed in Version | => 0.17 |
