| 0002533 | PartDesign | Bug | public | 2016-04-29 09:22 | 2016-07-15 12:18 |
| Reporter | ickby | Assigned To | ickby | ||
| Summary | 0002533: Loft works even with no active body | ||||
| Description | all PartDesign features should only work when an active body is available where they are added to. Currently if no active body is present and one uses body sketches for a loft it works and the loft is placed outside of the body. | ||||
| Steps To Reproduce | 1. Create body with 2 sketches that can be used for a loft 2. Save file and close it 3. Open file again 4. Select sketches and start creation of the Loft | ||||
I've made a pull request to fix this https://github.com/FreeCAD/FreeCAD/pull/211 |
Another try to fix loft and some other commands https://github.com/FreeCAD/FreeCAD/pull/213 |
| 2016-04-29 09:22 | ickby | New Issue | |
| 2016-04-29 09:22 | ickby | Status | new => assigned |
| 2016-04-29 09:22 | ickby | Assigned To | => ickby |
| 2016-07-12 04:16 | poserge | Note Added: 0007184 | |
| 2016-07-13 03:52 | poserge | Note Added: 0007185 | |
| 2016-07-15 12:18 | wmayer | Changeset attached | => FreeCAD Master master 9f0db2d9 |
| 2016-07-15 12:18 | wmayer | Status | assigned => closed |
| 2016-07-15 12:18 | wmayer | Resolution | open => fixed |
| 2016-07-15 12:18 | wmayer | Fixed in Version | => 0.17 |
