| 0002534 | Arch | Bug | public | 2016-04-29 14:11 | 2016-04-30 13:32 |
| Reporter | rockn | Assigned To | yorik | ||
| Platform | Linux Ubuntu | OS | 14.04 | OS Version | 64 bits |
| Summary | 0002534: Wrong incrementing of Exclude property in Arch Structural System | ||||
| Description | Once you start to exclude some axes in Structural System, the incrementing goes wrong. For example, if you exclude axe 0 and axe 3, the axe 0 is well excluded but then this is not the 3th axe that is excluded but the 4th. | ||||
| Steps To Reproduce | Create an Arch Structural System. Exlude axe 0 and 4. Axe 0 is well excluded. Axe 4 is not excluded. It should be. But instead Axe 5 is exluded. | ||||
I just tried now, and cant reproduce the problem... Doing this: 1) press the "axes" button 2) press the "structure" button and place a column somewhere 3) Select the column and the axes, and press the "structure" button again 4) In the created structural system, change the value of the "Exclude" property 5) Press the "recompute" button This works normally for me each time, the excluded numbers are at the correct location. The only thing is that the Exclude list begins with zero, so it doesn't necessarily match the axis numbers... |
Oh my .... You are right, this must be that the list begin with zero that lost me. My apologize for the noise. |
Maybe we should allow axes numbers to begin with zero, actually. I didn't do that because other numbering styles (A,B,C or I,II,III) don't have a zero, but we could allow it for (1,2,3) style. |
| 2016-04-29 14:11 | rockn | New Issue | |
| 2016-04-29 14:12 | yorik | Assigned To | => yorik |
| 2016-04-29 14:12 | yorik | Status | new => assigned |
| 2016-04-30 00:34 | yorik | Note Added: 0007029 | |
| 2016-04-30 07:09 | rockn | Note Added: 0007032 | |
| 2016-04-30 07:10 | rockn | Status | assigned => closed |
| 2016-04-30 07:10 | rockn | Resolution | open => unable to reproduce |
| 2016-04-30 07:10 | rockn | Fixed in Version | => 0.16 |
| 2016-04-30 13:32 | yorik | Note Added: 0007039 |
