| 0002535 | Arch | Bug | public | 2016-04-29 14:17 | 2016-09-05 16:26 |
| Reporter | rockn | Assigned To | yorik | ||
| Platform | Linux Ubuntu | OS | 14.04 | OS Version | 64 bits |
| Summary | 0002535: Can't remove totally exclude axe in Structural System. | ||||
| Description | Once you start to exlude some axe, but want to cancel that, you can't edit the Exluded list by removing all thing. It say : Invalid Input Input in line 1 is not a number But if you don't want excluded ae anymore you must be able to set nothing to line 1, or to remove the line 1 ... | ||||
| Steps To Reproduce | Create a Strutural System Exlude axes 0 and 4. Recompute Edit Exclue property list, delete all line. FreeCAD say : Invalid Input Input in line 1 is not a number | ||||
There is indeed a bug in the property editor of PropertyIntegerList. It doesn't accept an empty value. Also, changing the value of the edit field manually (without opening the dialog) is not saved (lost on recompute) |
First part is done, it is now possible to enter empty lists |
FreeCAD: master a38a78f6 2016-04-30 04:00:11 Details Diff |
Allow to enter empty values in PropertyFloatList and PropertyIntegerList - issue 0002535 |
Affected Issues 0002535 |
| mod - src/Gui/Widgets.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.cpp | Diff File | ||
FreeCAD: master cc167bd2 2016-09-05 18:25:32 Details Diff |
Allow to edit PropertyLists directly in the property editor - fixes 0002535,0002689 |
Affected Issues 0002535, 0002689 |
| mod - src/Gui/Widgets.h | Diff File | ||
| 2016-04-29 14:17 | rockn | New Issue | |
| 2016-04-29 14:18 | yorik | Assigned To | => yorik |
| 2016-04-29 14:18 | yorik | Status | new => assigned |
| 2016-04-30 00:38 | yorik | Note Added: 0007030 | |
| 2016-04-30 02:01 | yorik | Changeset attached | => FreeCAD Master master a38a78f6 |
| 2016-04-30 02:01 | yorik | Note Added: 0007031 | |
| 2016-09-05 14:11 | yorik | Relationship added | child of 0002689 |
| 2016-09-05 16:26 | yorik | Changeset attached | => FreeCAD Master master cc167bd2 |
| 2016-09-05 16:26 | yorik | Status | assigned => closed |
| 2016-09-05 16:26 | yorik | Resolution | open => fixed |
