| 0002546 | FEM | Feature | public | 2016-05-12 17:29 | 2016-08-14 21:09 |
| Reporter | HoWil | Assigned To | |||
| Summary | 0002546: FEM constraint parameters can't be smaller than 0,01 (N) | ||||
| Description | The FEM constraint parameters for area load can't be smaller than 0,01 (N). For simulations of fragile structures (like MEMS) is this to much and should be scalable with exponents like 1e-4 or 0,0001. Forces at least down to pN (1e-12) would be grate. | ||||
| Tags | FEM, GUI | ||||
It only apply to the GUI. You can set such small values by python. Tested on FreeCAD 0.17.8048 Start FreeCAD --> change to Start WorkBench --> Load the 3D FEM example in pyhton console forceobj = App.ActiveDocument.getObject("FemConstraintForce") forceobj.Force = 1E-12 copy from CalculiX input file *********************************************************** ** Node loads ** written by write_constraints_force function *CLOAD ** FemConstraintForce ** node loads on shape: Box:Face2 1,3,-0.0000000000000E+00 2,3,-0.0000000000000E+00 3,3,-0.0000000000000E+00 4,3,-0.0000000000000E+00 49,3,-0.0000000000000E+00 64,3,-8.3333333333333E-14 88,3,-8.3333333333333E-14 100,3,-8.3333333333334E-14 102,3,-8.3333333333333E-14 188,3,-1.6666666666667E-13 189,3,-1.6666666666667E-13 190,3,-1.6666666666667E-13 191,3,-1.6666666666667E-13 |
Replacing the standard spinbox with a quantity spinbox fixes the problem. |
| 2016-05-12 17:29 | HoWil | New Issue | |
| 2016-05-12 17:29 | HoWil | Tag Attached: FEM | |
| 2016-05-12 17:29 | HoWil | Tag Attached: GUI | |
| 2016-07-28 23:20 | berndhahnebach | Note Added: 0007223 | |
| 2016-08-14 21:07 | wmayer | Changeset attached | => FreeCAD Master master 99ad0b71 |
| 2016-08-14 21:09 | wmayer | Note Added: 0007273 | |
| 2016-08-14 21:09 | wmayer | Status | new => closed |
| 2016-08-14 21:09 | wmayer | Resolution | open => fixed |
| 2016-08-14 21:09 | wmayer | Fixed in Version | => 0.17 |
