| 0002548 | FreeCAD | Bug | public | 2016-05-13 11:50 | 2016-05-13 16:12 |
| Reporter | DeepSOIC | Assigned To | tanderson69 | ||
| OS | Windows | OS Version | 10 | ||
| Summary | 0002548: Overflow exception in DAGView | ||||
| Description | When creating a document dependency graph of a certain structure at once in a script, FreeCAD vanishes (closes with no error message or crash report) | ||||
| Steps To Reproduce | 1. Ensure DAGView is enabled. hint: to enable DAGView, go to Tools->Edit Parameters. Locate folder BaseApp->Preferences->DAGView, set boolean parameter named 'Enabled' to true. Restart FreeCAD. Then, you can find the DAGView window in View->Panels->DAG View (but it's not necessary to have the DAG view displayed for this test) 2. copy-paste this script to Py console:
After this script finishes running, FreeCAD almost immediately closes. | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7453 (Git) Build type: Release Branch: master Hash: af72ae09c143d9bb086a762b8cb9f1fb48ca3e5f Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 The exception causing this was traced in discussion: "Vanish (crash) probably in DAGView" http://forum.freecadweb.org/viewtopic.php?f=3&t=15705 Werner has made some changes to exception handling, so the bug probably behaves differently now: commit dd3f85d1a1b4d043fa7e86ab83508c6fa1a61345 https://github.com/FreeCAD/FreeCAD/commit/dd3f85d1a1b4d043fa7e86ab83508c6fa1a61345 | ||||
| 2016-05-13 11:50 | DeepSOIC | New Issue | |
| 2016-05-13 12:57 | tanderson69 | Assigned To | => tanderson69 |
| 2016-05-13 12:57 | tanderson69 | Status | new => assigned |
| 2016-05-13 13:06 | tanderson69 | Note Added: 0007088 | |
| 2016-05-13 16:11 | wmayer | Changeset attached | => FreeCAD Master master 81ee548f |
| 2016-05-13 16:12 | wmayer | Status | assigned => closed |
| 2016-05-13 16:12 | wmayer | Resolution | open => fixed |
| 2016-05-13 16:12 | wmayer | Fixed in Version | => 0.17 |
