| 0002549 | Path | Bug | public | 2016-05-13 21:50 | 2017-01-12 22:06 |
| Summary | 0002549: Segfault after import | ||||
| Description | Issue imported from https://github.com/yorikvanhavre/FreeCAD/issues/30 Start FC clean so you're at the 'start' page. Immediately open an .ngc file either by clicking it in the recent files list or by using the open file dialog. Select pre processor and wait for the path to load. Switch to Path WB. At this point, I get a segfault every time. If I switch to path before importing, it works fine. An Interesting side note:, if I open a file with the open dialog and select the preprocessor, it imports and zooms to show the full path. If I import the same file using the same post processor but initiate the import by clicking on it in the recent files list, it imports but doesn't zoom. | ||||
Problem 1) doesn't crash for me Problem 2) also doesn't happen for me... Can you check that a " Gui.SendMsgToActiveView("ViewFit") " correctly appears in the python console after import? If not, it might be because the pre-processor failed |
sliptonic commented on 24 Jan 2015 Problem 1) does seem to be resolved. I'm no longer crashing at that point. problem 2) remains. The viewfit message does not happen if I click from the 'recent files' list but does if I open it through the menu. I'm using the example_pre script and in both cases it executes the 'done pre-processing' line. |
Does problem 2) still happen to you? For me the opened file gets correctly zoomed, no matter if I open it from File->Open or from File->Recent |
Opening from either of the ways you mention causes normal zoom. However, opening by clicking on the link in the start page 'recent files' list loads without zoom. |
Crashes are entirely resolved. The zooming is odd but not really a bug or a problem. Closing. |
| 2016-05-13 21:50 | yorik | New Issue | |
| 2016-05-13 21:51 | yorik | Note Added: 0007092 | |
| 2016-05-13 21:52 | yorik | Reporter | yorik => sliptonic |
| 2016-05-13 21:52 | yorik | Description Updated | |
| 2016-05-13 21:52 | yorik | Note Added: 0007093 | |
| 2016-05-13 21:53 | yorik | Note Added: 0007094 | |
| 2016-05-31 18:33 | sliptonic | Note Added: 0007134 | |
| 2017-01-12 22:06 | sliptonic | Note Added: 0007686 | |
| 2017-01-12 22:06 | sliptonic | Status | new => closed |
| 2017-01-12 22:06 | sliptonic | Assigned To | => sliptonic |
| 2017-01-12 22:06 | sliptonic | Resolution | open => fixed |
