| 0002550 | Path | Bug | public | 2016-05-13 21:55 | 2016-07-03 17:18 |
| Reporter | dubstar-04 | Assigned To | sliptonic | ||
| Summary | 0002550: Selecting pathPocket on a circular pocket causes a segfault | ||||
| Description | Issue imported from https://github.com/yorikvanhavre/FreeCAD/issues/24 Screenshot of the model attached. This is repeatable with a number of models, pocket diameters, depths and tools. FreeCAD Output: uint DBusMenuExporterDBus::GetLayout(int, int, const QStringList&, DBusMenuLayoutItem&): Condition failed: menu *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 10 The Valgrind log is 15mb and I can't see anything of much use in there but If there is any more information I can provide please let me know. | ||||
yorikvanhavre commented on 11 Apr 2015 Is this still crashing with recent code? If yes, could you provide a sample file and a step-by-step method to reproduce the crash? |
sliptonic commented on 11 Apr 2015 I don't have the segfault anymore but I have a new bug. Open the file linked below. Switch to Path wb Create a project Select the floor of the circular pocket. Try to create a Path Pocket. For me, freecad locks up. If I've launched from a terminal, I see it attempting to offset wires in what looks like an infinite loop. https://dl.dropboxusercontent.com/u/9245675/circlepocket.fcstd |
wood-galaxy commented on 17 Apr 2015 I have the same behavior sliptonic describe. |
I'm no longer see the lockup. Maybe this got fixed with new OCC? OCC still doesn't offset pure circular pockets but doesn't lock up either. Libarea still works perfectly. I propose closing this. Default pocket is now libarea, so make sure you switch to OCC to test. |
Can't duplicate anymore. |
| 2016-05-13 21:55 | yorik | New Issue | |
| 2016-05-13 21:55 | yorik | File Added: a39addc6-95d8-11e4-9eec-6a9af94098b0.png | |
| 2016-05-13 21:56 | yorik | File Added: circlepocket.fcstd | |
| 2016-05-13 21:56 | yorik | Reporter | yorik => dubstar-04 |
| 2016-05-13 21:56 | yorik | Note Added: 0007095 | |
| 2016-05-13 21:57 | yorik | Note Added: 0007096 | |
| 2016-05-13 21:57 | yorik | Note Added: 0007097 | |
| 2016-07-02 14:54 | sliptonic | Note Added: 0007165 | |
| 2016-07-03 17:18 | sliptonic | Note Added: 0007176 | |
| 2016-07-03 17:18 | sliptonic | Status | new => closed |
| 2016-07-03 17:18 | sliptonic | Assigned To | => sliptonic |
| 2016-07-03 17:18 | sliptonic | Resolution | open => fixed |
