| 0002551 | Path | Bug | public | 2016-05-13 21:59 | 2016-05-31 15:51 |
| Summary | 0002551: Pocket segfaults on tool change | ||||
| Description | Issue imported from https://github.com/yorikvanhavre/FreeCAD/issues/17 sliptonic commented on 22 Dec 2014 Created a pathpocket for a padded sketch (see test file linked below) Open the compound, select the path and change the tool to '2'. Hit enter. After several seconds, FreeCAD will segfault. This doesn't happen with all tool diameters. https://dl.dropboxusercontent.com/u/9245675/pockettest.fcstd | ||||
yorikvanhavre commented on 29 Dec 2014 I don't get a crash, but the diameter is not correctly taken from the host project, needs to be fixed anyway. |
Can't reproduce the error with improved Path. |
The pathimprove changes affect how operations get the tool diameter. This problem no longer exists. |
| 2016-05-13 21:59 | yorik | New Issue | |
| 2016-05-13 21:59 | yorik | File Added: pockettest.fcstd | |
| 2016-05-13 21:59 | yorik | Note Added: 0007098 | |
| 2016-05-13 22:00 | yorik | Reporter | yorik => sliptonic |
| 2016-05-31 15:50 | sliptonic | Note Added: 0007132 | |
| 2016-05-31 15:51 | sliptonic | Note Added: 0007133 | |
| 2016-05-31 15:51 | sliptonic | Status | new => closed |
| 2016-05-31 15:51 | sliptonic | Assigned To | => sliptonic |
| 2016-05-31 15:51 | sliptonic | Resolution | open => fixed |
| 2016-05-31 15:51 | sliptonic | Fixed in Version | => 0.17 |
