| 0002552 | Path | Bug | public | 2016-05-13 22:02 | 2016-05-31 18:39 |
| Summary | 0002552: Path improperly generated | ||||
| Description | Issue imported from https://github.com/yorikvanhavre/FreeCAD/issues/14 sliptonic commented on 20 Dec 2014 This shape has two 90 degree corners but the path isn't the same for both. | ||||
yorikvanhavre commented on 29 Dec 2014 Indeed I also saw some incoherences in rounded corners of generated profiles... I'll investigate |
sliptonic commented on 29 Dec 2014 I made a cube with pockets on all six sides. Then created paths in the pockets. My intention was make a test object for exporting rotated gcode. Pockets on faces other than the top XY plane give some strange results, including arcs out of the plane being pocketed. image Next I imported multiple copies of the cube and rotated it so different shapes were on top. Pockets on top, always generate better. image The multi cube test object is available here: https://dl.dropboxusercontent.com/u/9245675/multicube.fcstd |
There are still plenty of path quality issues but the specific issues described here are no longer relevant. Closing this issue in favor of more discrete and solvable problems. |
| 2016-05-13 22:02 | yorik | New Issue | |
| 2016-05-13 22:02 | yorik | File Added: 45df2394-8837-11e4-9f18-43d9a4801361.png | |
| 2016-05-13 22:02 | yorik | Reporter | yorik => sliptonic |
| 2016-05-13 22:03 | yorik | Note Added: 0007099 | |
| 2016-05-13 22:03 | yorik | Note Added: 0007100 | |
| 2016-05-13 22:03 | yorik | File Added: 44c6382e-8f8c-11e4-84fc-6d3561c4c2bd.png | |
| 2016-05-13 22:04 | yorik | File Added: 6745100a-8f8c-11e4-826c-8e8fc743ffaf.png | |
| 2016-05-13 22:04 | yorik | File Added: multicube.fcstd | |
| 2016-05-31 18:39 | sliptonic | Note Added: 0007135 | |
| 2016-05-31 18:39 | sliptonic | Status | new => closed |
| 2016-05-31 18:39 | sliptonic | Assigned To | => sliptonic |
| 2016-05-31 18:39 | sliptonic | Resolution | open => unable to reproduce |
| 2016-05-31 18:39 | sliptonic | Fixed in Version | => 0.17 |
