| 0002578 | FreeCAD | Bug | public | 2016-06-06 01:05 | 2016-06-16 12:44 |
| Reporter | poserge | Assigned To | |||
| Platform | win64 | OS | Windows | OS Version | 7, 8, 10 |
| Summary | 0002578: Duplicate objects copied and exported | ||||
| Description | If several faces are selected on the object When I select several faces on the object and try to copy/paste that object, several copies of the object are pasted, although only one of the copies is actual object and others are grey entities in the Tree view. | ||||
| Steps To Reproduce | 1. Create new document. 2. Switch to Parts workbench 3. Create Cube 4. Select two or more faces on Cube via Ctrl + Click. 5. Copy object 6. Paste to new document or to the same document 7. Observe several entities in Tree view. | ||||
| Additional Information | I've tried to talk about the bug in the forum but unfortunately no one payed attention to it - http://forum.freecad.org/viewtopic.php?f=3&t=15994 I checked the code and found that SelectionSingleton::addSelection is adding separate objects to selection set for each picked face. Copy command calls MainWindow::createMimeDataFromSelection () which gets selection from Selection().getCompleteSelection(). I think this method should be filtering selection to avoid object duplicates. | ||||
Forgot to add Freecad version: OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7696 (Git) Build type: Release Branch: master Hash: 7287b479db556da7bc8d33dafc6d0a5b715d427e Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
FreeCAD: master dc17dbf5 2016-06-09 04:53:24 Committer: wmayer Details Diff |
filter selection to exclude object duplicates before export |
Affected Issues 0002578 |
FreeCAD: master 8902e18d 2016-06-09 06:09:06 Committer: wmayer Details Diff |
filter objects to exclude duplicates during copy |
| mod - src/Gui/MainWindow.cpp | Diff File | ||
FreeCAD: master c832fb55 2016-06-16 14:40:28 Details Diff |
+ issue 0002578: Duplicate objects copied and exported |
| mod - src/Gui/CommandDoc.cpp | Diff File | ||
| 2016-06-06 01:05 | poserge | New Issue | |
| 2016-06-06 01:12 | poserge | Note Added: 0007138 | |
| 2016-06-16 12:42 | wmayer | Changeset attached | => FreeCAD Master master c832fb55 |
| 2016-06-16 12:44 | wmayer | Changeset attached | => FreeCAD Master master 8902e18d |
| 2016-06-16 12:44 | wmayer | Changeset attached | => FreeCAD Master master dc17dbf5 |
| 2016-06-16 12:44 | wmayer | Status | new => closed |
| 2016-06-16 12:44 | wmayer | Resolution | open => fixed |
| 2016-06-16 12:44 | wmayer | Fixed in Version | => 0.17 |
