| 0002583 | Arch | Feature | public | 2016-06-11 14:56 | 2016-06-13 15:23 |
| Summary | 0002583: Precast concrete tools | ||||
| Description | A set of tools to quickly build standard precast structures like - beams - pillars - slabs - panels These should behave like other Arch Structure objects, but have additional properties to make their shape parametric. They should feature all the standards ways to mount these structures together (dents, etc) and support for metallic inserts. | ||||
FreeCAD: master 0dfc6678 2016-06-13 03:47:58 Details Diff |
Arch: added precast concrete presets & objects to structure tool - issue 0002853 |
Affected Issues 0002583 |
| add - src/Mod/Arch/ArchPrecast.py | Diff File | ||
| mod - src/Mod/Arch/ArchProfile.py | Diff File | ||
| mod - src/Mod/Arch/ArchStructure.py | Diff File | ||
| mod - src/Mod/Arch/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Arch/Resources/Arch.qrc | Diff File | ||
| add - src/Mod/Arch/Resources/ui/ParametersBeam.svg | Diff File | ||
| add - src/Mod/Arch/Resources/ui/ParametersDent.svg | Diff File | ||
| add - src/Mod/Arch/Resources/ui/ParametersIbeam.svg | Diff File | ||
| add - src/Mod/Arch/Resources/ui/ParametersPanel.svg | Diff File | ||
| add - src/Mod/Arch/Resources/ui/ParametersPillar.svg | Diff File | ||
| add - src/Mod/Arch/Resources/ui/ParametersSlab.svg | Diff File | ||
| mod - src/Mod/Arch/importIFC.py | Diff File | ||
| 2016-06-11 14:56 | yorik | New Issue | |
| 2016-06-11 14:56 | yorik | Status | new => assigned |
| 2016-06-11 14:56 | yorik | Assigned To | => yorik |
| 2016-06-11 14:57 | yorik | Project | FreeCAD => Arch |
| 2016-06-13 01:35 | yorik | Note Added: 0007142 | |
| 2016-06-13 01:49 | yorik | Changeset attached | => FreeCAD Master master 0dfc6678 |
| 2016-06-13 15:23 | yorik | Note Added: 0007144 | |
| 2016-06-13 15:23 | yorik | Status | assigned => closed |
| 2016-06-13 15:23 | yorik | Resolution | open => fixed |
| 2016-06-13 15:23 | yorik | Fixed in Version | => 0.17 |
