| 0002584 | Arch | Feature | public | 2016-06-11 15:06 | 2021-09-06 10:08 |
| Summary | 0002584: Support for SweetHome3D xml-based files | ||||
| Description | SweetHome3D ( http://www.sweethome3d.com/ ) has a plugin ( http://www.sweethome3d.com/blog/2016/05/05/export_to_html5_plug_in.html ) that exports the contents of a file as a zip that contains a master xml file describing the walls and the objects placements, and an obj file for each piece of furniture. This format could be easily imported and exported by FreeCAD. Currently that .zip is not reimportable in SH3D, but that's in their plans... | ||||
| Additional Information | Using Yorik's SweetHome3D importer https://forum.freecadweb.org/viewtopic.php?f=23&t=16205 Sweet Home 3D integration/collaboration - https://forum.freecadweb.org/viewtopic.php?f=8&t=23965 | ||||
| Tags | #lowhangingfruit, export, import | ||||
New version of the plugin that exports walls as xml: http://www.sweethome3d.com/plugins/ExportToXMLOBJ-1.1.sh3p see annexed example file Discussion thread: http://www.sweethome3d.com/support/forum/viewthread_thread,6708_offset,25 Discussion about reimporting such data in SH3d: http://www.sweethome3d.com/support/forum/viewthread_thread,6708_offset,20 |
@yorik FYI plugins updated per http://www.sweethome3d.com/support/forum/viewthread_thread,6708_offset,30#32844Here's the new versions 1.2 of Export to HTML5 and Export to XML/OBJ plug-ins. |
Yes the plugin is now part of the 5.3 version, no need to install anything more, normally. I still need to test, though |
@yorik can you test this and confirm ? |
Relevant: SweetHome3D HTML5/XML to Blender importer |
Progress made by user 'laschrocket' in https://forum.freecadweb.org/viewtopic.php?p=530893#p530893 |
This ticket has been migrated to GitHub as issue 5658. |
| 2016-06-11 15:06 | yorik | New Issue | |
| 2016-06-11 15:06 | yorik | Status | new => assigned |
| 2016-06-11 15:06 | yorik | Assigned To | => yorik |
| 2016-06-11 15:07 | yorik | Project | FreeCAD => Arch |
| 2016-06-13 14:41 | yorik | Note Added: 0007143 | |
| 2016-06-13 14:41 | yorik | File Added: testhouse.zip | |
| 2016-06-16 01:29 | yorik | Changeset attached | => FreeCAD Master master 3510c71f |
| 2017-03-27 15:33 | Kunda1 | Note Added: 0008715 | |
| 2017-03-27 15:33 | Kunda1 | Note Edited: 0008715 | |
| 2017-03-27 15:56 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2017-05-02 22:56 | yorik | Note Added: 0008872 | |
| 2017-08-14 00:24 | Kunda1 | Note Added: 0009925 | |
| 2018-01-12 15:09 | yorik | Target Version | => 0.18 |
| 2018-06-07 21:53 | Kunda1 | Note Added: 0011365 | |
| 2018-06-07 21:57 | Kunda1 | Additional Information Updated | |
| 2018-10-03 16:41 | Kunda1 | Tag Attached: import | |
| 2018-10-03 16:41 | Kunda1 | Tag Attached: export | |
| 2019-02-15 00:25 | yorik | Target Version | 0.18 => 0.19 |
| 2021-02-06 06:28 | abdullah | Target Version | => 0.20 |
| 2021-09-06 10:08 | Kunda1 | Note Added: 0015902 |
