| 0002585 | Path | Bug | public | 2016-06-11 18:33 | 2016-07-27 00:37 |
| Reporter | linden11 | Assigned To | sliptonic | ||
| Priority | normal | Severity | minor | Reproducibility | random |
| Platform | Linux | OS | mint 17 | ||
| Summary | 0002585: strange warnings/error in when generating new path | ||||
| Description | create paths with new surface strategy crashes free cad intermittently when change parameters in the tree usaly switching from default drop cutter to waterline algorithm | ||||
| Steps To Reproduce | See forum post http://forum.freecadweb.org/viewtopic.php?f=15&t=15909 | ||||
| Additional Information | See forum post http://forum.freecadweb.org/viewtopic.php?f=15&t=15909 I have replaced my very old opencamlib with a freshly compiled one from here https://github.com/aewallin/opencamlib This may be unrelated but path seems to crash much less now. | ||||
Linden, Please supply your freecad info and double check that you've pulled and rebuilt since May 31. This commit https://github.com/FreeCAD/FreeCAD/commit/4568a4e583eec4095ea57aabc1cd4218a4670d1a included some fixes for PathSurface to make sure it stored settings correctly. It might be material to this issue. |
Still here but much better we are making progress I can select waterline with step down of 2mm and above and no crash Below 2 mm i get either an error or a crash bellow are the errors , freecad info and attached is the test file error no crash 32/40: Traceback (most recent call last): File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathSurface.py", line 313, in execute output = self._waterline(obj, s, bb) File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathSurface.py", line 192, in _waterline output += drawLoops(loops) File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathSurface.py", line 150, in drawLoops " Z" + str(fmt(zheight)) + "\n" <type 'exceptions.UnboundLocalError'>: local variable 'zheight' referenced before assignment Error crash Hold on. This might take a minute. calculating Waterline at z= 38.5185185185 calculating Waterline at z= 37.037037037 terminate called after throwing an instance of 'std::length_error' what(): basic_string::_S_create Aborted Freecad info: OS: Linux Mint 17 Qiana Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7713 (Git) Build type: None Branch: master Hash: a363d6ff7c7962d522d2bf8edf3646a011bd7236 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
PR 0000201 |
| 2016-06-11 18:33 | linden11 | New Issue | |
| 2016-06-11 22:55 | sliptonic | Note Added: 0007140 | |
| 2016-06-12 04:20 | linden11 | Note Added: 0007141 | |
| 2016-06-12 04:22 | linden11 | File Added: test44.fcstd | |
| 2016-07-03 15:20 | sliptonic | Assigned To | => sliptonic |
| 2016-07-03 15:20 | sliptonic | Status | new => assigned |
| 2016-07-03 17:11 | sliptonic | Note Added: 0007170 | |
| 2016-07-03 17:11 | sliptonic | Status | assigned => resolved |
| 2016-07-03 17:11 | sliptonic | Resolution | open => fixed |
| 2016-07-27 00:37 | yorik | Status | resolved => closed |
| 2016-07-27 00:37 | yorik | Fixed in Version | => 0.17 |
