0002587PartDesignBugpublic2016-06-18 08:18
Reporterulrich1a Assigned Toeivindkvedalen
Status closedResolutionfixed
OSDebianOS VersionJessie
Product Version0.16
Fixed in Version0.16
Summary0002587: Angle Expressions deliver radiants with ° as unit
DescriptionExpressions, which refers to an angle, results in an angle in radiant with a degree unit. See also http://forum.freecad.org/viewtopic.php?f=3&t=16131#p127731
Steps To Reproduce- Make a sketch with a named angle constraint.
- Define a second angle constraint in that sketch and put an expression in, which refers to the named angle constraint.
The second angle constraint has a different angle than the named angle constraint.
The problem can be seen in the attached file Angle_Expression_Problem_Sketch.fcstd
ulrich1a
2016-06-12 08:48
reporter
eivindkvedalen
2016-06-14 05:16
developer   ~0007145
Please test https://github.com/eivindkv/free-cad-code/tree/Sketcher_fix_20160614 (rebased to current master), and see if this fixes the problem. This also adds units to sketcher constraints when used in expressions or from the spreadsheet.
ulrich1a
2016-06-16 20:17
reporter   ~0007152
I compiled the branch. It solves the problem with the angle expression and as well the problem with the missing unit in the spreadsheet.
Related Changesets
FreeCAD: master 171fce7b
2016-06-13 20:27:48
Eivind Kvedalen
Sketcher: Fixed radian/degree mix-up for Angle constraint. Affected Issues
0002587
mod - src/Mod/Sketcher/App/Constraint.cpp Diff File
mod - src/Mod/Sketcher/Gui/TaskSketcherConstrains.cpp Diff File
mod - src/Mod/Sketcher/Gui/ViewProviderSketch.cpp Diff File
FreeCAD: master 7afcb4be
2016-06-14 01:13:33
Eivind Kvedalen
Sketcher: Changed return type of Constraint::getPresentationValue() to Quantity, to be able to include unit. Affected Issues
0002587
mod - src/Mod/Sketcher/App/Constraint.h Diff File
2016-06-12 08:48 ulrich1a New Issue
2016-06-12 08:48 ulrich1a File Added: Angle_Expression_Problem_Sketch.fcstd
2016-06-14 05:16 eivindkvedalen Note Added: 0007145
2016-06-14 05:16 eivindkvedalen Assigned To => eivindkvedalen
2016-06-14 05:16 eivindkvedalen Status new => assigned
2016-06-16 20:17 ulrich1a Note Added: 0007152
2016-06-18 08:17 wmayer Changeset attached => FreeCAD Master master 7afcb4be
2016-06-18 08:18 wmayer Changeset attached => FreeCAD Master master 171fce7b
2016-06-18 08:18 wmayer Status assigned => closed
2016-06-18 08:18 wmayer Resolution open => fixed
2016-06-18 08:18 wmayer Fixed in Version => 0.16
