| 0000259 | FreeCAD | Bug | public | 2011-02-10 10:53 | 2011-03-30 09:16 |
| Target Version | 0.12 | Fixed in Version | 0.12 | ||
| Summary | 0000259: Can't select points in Sketcher | ||||
| Description | draw a rectangle in the draft module, new sketch, draw a box in sketcher, one can't select points of the box FreeCAD_0.11.3987_x86_unstable_setup.msi | ||||
I don't think it's a bug because point selection is not implemented. It only works when editing a sketch but otherwise not. |
I mean when editing a sketch. So: new file -> draw rectangle (draft module) -> new sketch -> draw a box (in sketcher) -> try to select a point (still in "editmode" of Sketcher) -> if you click on a point the point wont become green, if you mouseover a point the point wont become blue. If you draw a sketch without having drawn something with the Draft module the point becomes blue/green when in "editmode" of Sketcher. |
I can not reproduce this error!? I can select and drag a point in a sketch in edit. And what you mean with Draft? |
To reproduce this you HAVE to draw something with the "draft module" FIRST. If you use Sketcher WITHOUT drawing something with the "Draft module" first it WORKS. 1. Draw some circles or rectangles 2. Draw a box in Sketcher and try to click on a point -> the point wont be selected (wont become blue) Draft module: http://sourceforge.net/apps/mediawiki/free-cad/index.php?title=Draft_Workbench |
yes, I can see this too. But you DO select them, only they do not change color when they are selected, nor when you hoover mouse over them Regards Petar Perisin |
Yes I think I should have called it mark instead of select. (Or color ??) |
Yes, now I can see this behaviour, too. |
Ok confirmed. strange behaviour!? |
This error seems to be solved now. I don't know which of the many changes in the sketcher module fix it but it is not there any more. |
| 2011-02-10 10:53 | unauthenticated | New Issue | |
| 2011-02-10 12:56 | wmayer | Note Added: 0000586 | |
| 2011-02-10 12:56 | wmayer | Assigned To | => Jriegel |
| 2011-02-10 12:56 | wmayer | Status | new => assigned |
| 2011-02-10 15:26 | unauthenticated | Note Added: 0000589 | |
| 2011-02-10 18:52 |
Note Added: 0000591 | |
| 2011-02-10 19:28 | unauthenticated | Note Added: 0000592 | |
| 2011-02-10 21:23 | pperisin | Note Added: 0000593 | |
| 2011-02-10 22:07 | unauthenticated | Note Added: 0000594 | |
| 2011-02-10 23:30 | wmayer | Note Added: 0000596 | |
| 2011-02-10 23:30 | wmayer | Status | assigned => confirmed |
| 2011-02-11 14:35 |
Note Added: 0000607 | |
| 2011-02-11 14:39 |
Target Version | => 0.11 |
| 2011-03-30 09:12 | wmayer | Note Added: 0000759 | |
| 2011-03-30 09:12 | wmayer | Status | confirmed => closed |
| 2011-03-30 09:12 | wmayer | Resolution | open => fixed |
| 2011-03-30 09:12 | wmayer | Fixed in Version | => trunk |
| 2011-03-30 09:16 | wmayer | Fixed in Version | trunk => 0.12 |
| 2011-03-30 09:16 | wmayer | Target Version | 0.11 => 0.12 |
