| 0002594 | FreeCAD | Bug | public | 2016-06-16 11:16 | 2016-08-05 09:32 |
| Reporter | trampas | Assigned To | |||
| Priority | normal | Severity | minor | Reproducibility | random |
| Platform | windows | OS | windows 10 | OS Version | windows 10 |
| Summary | 0002594: Part move does not deselect | ||||
| Description | If I double click on a part in the "combo view" the part placement/move arrows show up however if I double click on the part a second time the part placement arrows do not remove and is still active. | ||||
| Steps To Reproduce | see above. | ||||
| Additional Information | I have noticed that if I double click on the sub part it will remove the placement arrows in the display. | ||||
You should not double-click again because it's not implemented as a toggle command. Instead you have to open the context menu and click on Finish or press the ESC button while the 3d view has the focus. In 0.17 this has been reworked to make it more user-friendly. When setting an object in transform mode a dialog comes up in the task panel and you simply have to click on OK to finish the edit mode. |
