| 0000261 | FreeCAD | Bug | public | 2011-02-10 10:57 | 2011-02-26 18:01 |
| Reporter | unauthenticated | Assigned To | yorik | ||
| Summary | 0000261: awesome undo feature | ||||
| Description | I found the easter egg :) Double clicking on circle, arc or regular polygon icon undo the last step (pressing the Esc key after that will undo another step) FreeCAD_0.11.3987_x86_unstable_setup.msi | ||||
I cannot confirm the double undo but there is a problem with the undo for custom objects because they loose the python proxy objects. |
So when you start FreeCAD and draw lets say three rectangles and after that double click on the circle button there is nothing undone? If I double click on the circle button (also arc, polygon) it has the same effect as I would click on the undo button or pressing Ctrl+Z. |
Here is a screencapture: http://rapidshare.com/files/447271441/doubleclick.ogg |
hm indeed I see the problem too... funny ;) I'll solve that ASAP, double-clicking an icon is not supposed to undo stuff! About real undoing custom python objects, undoing works fine, but indeed redoing them doesn't work. |
fixed in r4038 |
Seems like this behavior was only fixed for the arc and circle button but not for the regular polygon icon/button. FreeCAD_0.11.4134_x86_RC_bin.7z |
oops, indeed... seems I forgot one :) fixed in r4144 now. If something's still missing. please reopen! |
| 2011-02-10 10:57 | unauthenticated | New Issue | |
| 2011-02-10 12:58 | wmayer | Note Added: 0000587 | |
| 2011-02-10 12:58 | wmayer | Assigned To | => wmayer |
| 2011-02-10 12:58 | wmayer | Status | new => assigned |
| 2011-02-10 15:33 | unauthenticated | Note Added: 0000590 | |
| 2011-02-10 22:12 | unauthenticated | Note Added: 0000595 | |
| 2011-02-10 23:36 | wmayer | Assigned To | wmayer => yorik |
| 2011-02-11 13:05 | yorik | Note Added: 0000603 | |
| 2011-02-11 13:12 | yorik | Note Added: 0000604 | |
| 2011-02-11 13:12 | yorik | Status | assigned => closed |
| 2011-02-11 13:12 | yorik | Resolution | open => fixed |
| 2011-02-11 13:12 | yorik | Fixed in Version | => 0.12 |
| 2011-02-26 17:55 | unauthenticated | Note Added: 0000651 | |
| 2011-02-26 17:55 | unauthenticated | Status | closed => feedback |
| 2011-02-26 17:55 | unauthenticated | Resolution | fixed => reopened |
| 2011-02-26 18:01 | yorik | Note Added: 0000652 | |
| 2011-02-26 18:01 | yorik | Status | feedback => closed |
| 2011-02-26 18:01 | yorik | Resolution | reopened => fixed |
| 2011-02-26 18:01 | yorik | Fixed in Version | 0.12 => 0.11 |
