| 0002612 | FreeCAD | Bug | public | 2016-07-06 06:55 | 2016-07-16 16:17 |
| Reporter | vejmarie | Assigned To | vejmarie | ||
| Platform | MacbookPro | OS | MacOS | OS Version | ElCapitan |
| Summary | 0002612: Mefisto Mesh generation is broken with SMESH 7 upgrade | ||||
| Description | Mefisto Mesh generation through MeshPart is broken and doesn't generate any mesh. This is happening only with SMESH 7 upgrade | ||||
| Steps To Reproduce | Create a Part element (cylinder, or cube) try to Mesh it with the PartMesher using Mefisto | ||||
I just issue PR 0000208 which integrate the fix for this issue. It was coming from a bad definition of the function areteideale (and calls), which was returning aretemaxface_ as value, without changing it as input parameter but call return. Fortran part of aptrte requires the input parameter to be modified instead the return value areteideale(R &_areteideale) { _areteideale = aretemaxface_; return(_areteideale) } I am still returning the value to keep the C code style of aptrte, but this is probably not the cleanest way to make it. |
| 2016-07-06 06:55 | vejmarie | New Issue | |
| 2016-07-06 07:52 | wmayer | Assigned To | => vejmarie |
| 2016-07-06 07:52 | wmayer | Status | new => assigned |
| 2016-07-08 20:28 | vejmarie | Note Added: 0007179 | |
| 2016-07-08 20:29 | vejmarie | Status | assigned => resolved |
| 2016-07-08 20:29 | vejmarie | Resolution | open => fixed |
| 2016-07-16 16:17 | wmayer | Status | resolved => closed |
| 2016-07-16 16:17 | wmayer | Fixed in Version | => 0.17 |
