| 0002614 | Draft | Bug | public | 2016-07-09 08:29 | 2016-10-09 17:20 |
| Reporter | flokart | Assigned To | yorik | ||
| Platform | windows | ||||
| Summary | 0002614: Parametric draft dimension isnt working | ||||
| Description | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7801 (Git) Build type: Release Branch: master Hash: 09e9c8966fc9968e05bc433425302b2c9dc10491 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 | ||||
| Steps To Reproduce | -creat a line and a arch -use dimension tool in draft and select with ALT button the edge (line) -use dimension tool in draft and select with ALT SHIFT the arch Result show all time only 1 mm and is not parametric. Only Angle seams to work. | ||||
| Additional Information | Report in the forum with pictures. http://forum.freecadweb.org/viewtopic.php?f=3&t=16490&p=130399#p130399 | ||||
| 2016-07-09 08:29 | flokart | New Issue | |
| 2016-07-09 15:15 | yorik | Note Added: 0007180 | |
| 2016-07-09 15:15 | yorik | Assigned To | => yorik |
| 2016-07-09 15:15 | yorik | Status | new => assigned |
| 2016-07-09 15:15 | yorik | Priority | high => normal |
| 2016-07-09 15:16 | yorik | Relationship added | child of 0001804 |
| 2016-07-09 16:57 | flokart | Note Added: 0007182 | |
| 2016-10-09 17:20 | yorik | Changeset attached | => FreeCAD Master master 0704ad0b |
| 2016-10-09 17:20 | yorik | Status | assigned => closed |
| 2016-10-09 17:20 | yorik | Resolution | open => fixed |
