| 0002615 | Path | Bug | public | 2016-07-10 18:39 | 2016-08-11 11:47 |
| Reporter | Hackscribble | Assigned To | sliptonic | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002615: Unable to create profile path for bottom face of part | ||||
| Description | Creating a profile path for the bottom face of a part adds a path object to the tree. However, no path is visible and no G-code is created. Report view says "Face doesn't appear to be parallel or perpendicular to the XY plane. No path will be generated for: Pocket.Face5". | ||||
| Steps To Reproduce | 1. Load test file "test2.fcstd" 2. Select Path workbench 3. Rotate part and select bottom face. 4. Click on "Create profile path" button. 5. Click on "OK" in task window. | ||||
| Additional Information | OS: Ubuntu 16.04 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7833 (Git) Build type: None Branch: master Hash: d9b7a5fbbf7c444c7ab94473a11449840a946313 Python version: 2.7.11+ Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
FreeCAD: master 0ea9cc8c 2016-08-02 21:38:42 sliptonic Committer: Yorik van Havre Details Diff |
Bug fixes: fixes reparenting bug when dressup is deleted Engrave wasn't using final depth value Dragknife Dressup not correctly calculating spin direction or curve intersection Per Yorik, fix crash if PartGui hasn't been loaded Allow selection of bottom face for profiling Bug # 0002615 |
Affected Issues 0002615 |
| mod - src/Mod/Path/Gui/AppPathGui.cpp | Diff File | ||
| mod - src/Mod/Path/Gui/Resources/panels/EngraveEdit.ui | Diff File | ||
| mod - src/Mod/Path/PathScripts/DragknifeDressup.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathDressup.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathEngrave.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPocket.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathProfile.py | Diff File | ||
| 2016-07-10 18:39 | Hackscribble | New Issue | |
| 2016-07-10 18:39 | Hackscribble | File Added: test2.fcstd | |
| 2016-08-02 19:48 | sliptonic | Assigned To | => sliptonic |
| 2016-08-02 19:48 | sliptonic | Status | new => assigned |
| 2016-08-02 19:49 | sliptonic | Note Added: 0007238 | |
| 2016-08-02 19:49 | sliptonic | Status | assigned => resolved |
| 2016-08-02 19:49 | sliptonic | Resolution | open => fixed |
| 2016-08-11 11:46 | wmayer | Changeset attached | => FreeCAD Master master 0ea9cc8c |
| 2016-08-11 11:47 | wmayer | Status | resolved => closed |
| 2016-08-11 11:47 | wmayer | Fixed in Version | => 0.17 |
