| 0002619 | FreeCAD | Bug | public | 2016-07-13 06:29 | 2016-07-14 13:52 |
| Reporter | Jean-Luc | Assigned To | wandererfan | ||
| Platform | Intel | OS | Debian sid / GNU - Linux | OS Version | Linux 4.6.3 |
| Summary | 0002619: Failed to build | ||||
| Description | Hi, This applies to git/master. It failed to build since a couple of days. The cmake step is fine. Then I've several warning/errors doing make et evenutally fails completely. Attached the cmake log and the make log Regards Jean-Luc | ||||
This forum post suggests a fix for Debian Sid build failure. http://www.forum.freecadweb.org/viewtopic.php?f=27&p=130767#p130725 Does it help? |
Hi, Yes, it works that way. Thanks Jean-Luc |
work around by adding comment to Cmake file |
| 2016-07-13 06:29 | Jean-Luc | New Issue | |
| 2016-07-13 06:29 | Jean-Luc | File Added: make.log | |
| 2016-07-13 06:30 | Jean-Luc | File Added: cmake.log | |
| 2016-07-13 13:45 | wandererfan | Note Added: 0007186 | |
| 2016-07-13 14:42 | Jean-Luc | Note Added: 0007188 | |
| 2016-07-14 13:51 | wandererfan | Status | new => resolved |
| 2016-07-14 13:52 | wandererfan | Note Added: 0007189 | |
| 2016-07-14 13:52 | wandererfan | Status | resolved => closed |
| 2016-07-14 13:52 | wandererfan | Assigned To | => wandererfan |
| 2016-07-14 13:52 | wandererfan | Resolution | open => fixed |
