| 0002623 | Path | Feature | public | 2016-07-13 20:30 | 2016-10-22 17:04 |
| Platform | all | ||||
| Summary | 0002623: Add Jog speed to tool control | ||||
| Description | Some cnc controllers like ShopBot can independently set the default travel rate for jog moves separately from feed moves. We should add a jog speed property to the tool controller and then output this value whenever we output a G0 move. Post processors can either handle the jog rate or ignore it as appropriate. | ||||
Tool Controllers now save the properties for vert and horiz rapid speed as well as feed speed. It's up to the post processors to do anything with this data. Basic operations might still need to be modified to add the rapid speed values to the path commands. |
| 2016-07-13 20:30 | sliptonic | New Issue | |
| 2016-07-13 20:30 | sliptonic | Status | new => assigned |
| 2016-07-13 20:30 | sliptonic | Assigned To | => sliptonic |
| 2016-10-22 17:04 | sliptonic | Note Added: 0007415 | |
| 2016-10-22 17:04 | sliptonic | Status | assigned => closed |
| 2016-10-22 17:04 | sliptonic | Resolution | open => fixed |
