| 0002627 | FreeCAD | Bug | public | 2016-07-18 20:26 | 2016-07-22 14:59 |
| Reporter | ronp | Assigned To | wandererfan | ||
| Summary | 0002627: Dimensions in TechDraw show mm value when imperial selected | ||||
| Description | This problem appears in Freecad compiled from source, revision 7976. Dimensions shown in TechDraw show the value in mm when Imperial decimal (in/lb) units are selected. For example a dimension of 1.25 inches is printed as 34.544 in. When the units in preferences are changed to Standard (mm/kg/s/degree), the same dimension is correctly printed as 34.544 mm. The problem occurs in the file src/Mod/TechDraw/App/DrawViewDimension.cpp in the function DrawViewDimension::getFormatedValue. The dimension is converted to a string named userStr on line 218 which correctly contains the value in inches when using Imperial decimal (in/lb). However, userStr is parsed and a new string named displayText is created in line 223 which is a concatenation of valText and unitText. Because valText was created before localized unit conversion, it represents the value in mm. String unitText correctly holds the localized units. Therefore, when using Imperial units, displayText is a mixture of a mm value and an imperial unit. String displayText is the dimension shown in TechDraw. This may have been introduced in change 350d8bb55be292e80667626cdc22bbd4d83e8b74. | ||||
| Steps To Reproduce | 1 Set the Unit preferences in Freecad to Imperial decimal (in/lb). 2 Open an existing part. 3 Create a new TechDraw drawing. 4 Insert a view of part into TechDraw drawing. 5 Add some dimensions. 6 Observe the units are imperial (in) but values are multiplied by 25.4 7 Save drawing. 8 Set the Unit preferences in Freecad to Standard (mm/kg/s/degree). 9 Restart Freecad 10 Open drawing and observe dimensions are printed with same values but units of mm. | ||||
| Additional Information | A work around is to use the original string containing the dimension in the chosen units with the change shown below. This isn't ideal because the decimal setting of the dimension is ignored. --- a/src/Mod/TechDraw/App/DrawViewDimension.cpp +++ b/src/Mod/TechDraw/App/DrawViewDimension.cpp @@ -234,7 +234,7 @@ std::string DrawViewDimension::getFormatedValue() const for(QStringList::const_iterator it = list.begin(); it != list.end(); ++it) { if(*it == QString::fromAscii("%value%")){ - str.replace(*it,displayText); + str.replace(*it, userStr);^M } else { //insert additional placeholder replacement logic here str.replace(*it, QString::fromAscii("")); //maybe we should just leave what was there? } | ||||
Correction to description: a dimension of 1.25 inches is printed as 31.75 in. |
Your workaround is how it used to work. I was trying to get around Quantity::getUserString always returning 6 digit precision. We'll have to fix getUserString. |
| 2016-07-18 20:26 | ronp | New Issue | |
| 2016-07-18 20:40 | ronp | Note Added: 0007200 | |
| 2016-07-20 20:03 | wandererfan | Note Added: 0007206 | |
| 2016-07-20 20:03 | wandererfan | Assigned To | => wandererfan |
| 2016-07-20 20:03 | wandererfan | Status | new => confirmed |
| 2016-07-20 20:03 | wandererfan | Product Version | => 0.17 |
| 2016-07-20 20:03 | wandererfan | Target Version | => 0.17 |
| 2016-07-22 14:58 | wmayer | Changeset attached | => FreeCAD Master master 62a8828d |
| 2016-07-22 14:59 | wmayer | Status | confirmed => closed |
| 2016-07-22 14:59 | wmayer | Resolution | open => fixed |
| 2016-07-22 14:59 | wmayer | Fixed in Version | => 0.17 |
