| 0002633 | PartDesign | Bug | public | 2016-07-22 21:48 | 2016-12-10 05:24 |
| Reporter | normandc | Assigned To | wmayer | ||
| Platform | Linux 64-Bit | OS | Ubuntu | OS Version | 14.04.4 LTS |
| Summary | 0002633: Bodies disappear from 3D view if dragged out of Part container | ||||
| Description | PartDesign Bodies can be dragged out of a Part container in the Model tree. But doing so makes them disappear from view. Even a force recompute will not make them reappear. It's not a zoom issue either, tested zoom fit all with no result. The bodies appear again only if the file is saved, closed then reopened. | ||||
| Steps To Reproduce | 1. Open attached file (017_PDNext_disappearing_bodies.fcstd). 2. In the Model tree, drag both Body and Body001 from the Part container by dropping them on the document label. 3. Both bodies are listed at the bottom of the Model tree, outside of the Part container; they disappear from the 3D view. Python console output: >>>App.getDocument("_17_PDNext_disappearing_bodies").getObject("Part").removeObject(App.getDocument("_17_PDNext_disappearing_bodies").getObject("Body")) >>>App.getDocument("_17_PDNext_disappearing_bodies").getObject("Part").removeObject(App.getDocument("_17_PDNext_disappearing_bodies").getObject("Body001")) 4. Use of http://www.freecadweb.org/wiki/index.php?title=Macro_ForceRecompute has no effect. 5. Save then close file. 6. Reopen the file in FreeCAD, both bodies can now be seen. | ||||
| Additional Information | OS: Ubuntu 14.04.4 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8019 (Git) Build type: None Branch: master Hash: 5c2ffb784a0178ad1b72b44ce2f95d09771a8286 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| 2016-07-22 21:48 | normandc | New Issue | |
| 2016-07-22 21:48 | normandc | File Added: 017_PDNext_disappearing_bodies.fcstd | |
| 2016-07-22 21:56 | normandc | Description Updated | |
| 2016-07-22 21:56 | normandc | Steps to Reproduce Updated | |
| 2016-11-29 14:25 | ickby | Assigned To | => ickby |
| 2016-11-29 14:25 | ickby | Status | new => assigned |
| 2016-12-09 21:17 | wmayer | Changeset attached | => FreeCAD Master master 12b0e0f9 |
| 2016-12-09 21:17 | wmayer | Assigned To | ickby => wmayer |
| 2016-12-09 21:17 | wmayer | Status | assigned => closed |
| 2016-12-09 21:17 | wmayer | Resolution | open => fixed |
