| 0002638 | FreeCAD | Bug | public | 2016-07-24 04:39 | 2016-07-24 09:30 |
| Reporter | oneirag | Assigned To | |||
| Priority | low | Severity | trivial | Reproducibility | have not tried |
| Platform | Windows | OS | Windows 10 | OS Version | 64 bit |
| Summary | 0002638: Windows installer doesn't create the macro folder | ||||
| Description | The installer doesn't create the C:/Users/<name_of_windows_user>/AppData/Roaming/FreeCAD/Macro folder during the installation process, therefore user macro fails to run (e.g. the dxf importer, that has to be manually installed when importing a dwg file, even if the program lets you do it automatically it does not work due to the inexistence of the mentioned folder) | ||||
| Steps To Reproduce | remove C:/Users/<name_of_windows_user>/AppData/Roaming/FreeCAD folder and its contents and reinstall freecad. | ||||
| 2016-07-24 04:39 | oneirag | New Issue | |
| 2016-07-24 09:26 | wmayer | Changeset attached | => FreeCAD Master master f00a0b1a |
| 2016-07-24 09:29 | wmayer | Note Added: 0007214 | |
| 2016-07-24 09:29 | wmayer | Status | new => closed |
| 2016-07-24 09:30 | wmayer | Resolution | open => fixed |
| 2016-07-24 09:30 | wmayer | Fixed in Version | => 0.17 |
