| 0002640 | FEM | Bug | public | 2016-07-25 09:42 | 2017-01-09 14:52 |
| Reporter | ilyxa | Assigned To | |||
| Priority | low | Severity | crash | Reproducibility | always |
| Platform | x86_64 | OS | Arch | OS Version | Linux 4.6.4 |
| Summary | 0002640: FEM crash | ||||
| Description | Catchpoint 1 (signal SIGSEGV), 0x00007fffbeec8a57 in QMetaObject::className() const () from /usr/lib/libQt5Core.so.5 | ||||
| Steps To Reproduce | run freecad (gdb freecad, catch signal, run), select FEM workbench. | ||||
| Additional Information | OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8044 (Git) Build type: Unknown Branch: makepkg Hash: 41307ef5a18e36e9d29bc90dbfe05a0fa15aef23 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 | ||||
[ilyxa@orca freecad-git]$ LC_ALL=C gdb freecad GNU gdb (GDB) 7.11.1 Copyright (C) 2016 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-pc-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/> Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/> For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from freecad...(no debugging symbols found)...done. (gdb) catch signal Catchpoint 1 (standard signals) (gdb) r Starting program: /usr/bin/freecad [Thread debugging using libthread_db enabled] Using host libthread_db library "/usr/lib/libthread_db.so.1". FreeCAD 0.17, Libs: 0.17R8044 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Catchpoint 1 (signal SIGSEGV), 0x00007fffbeec8a57 in QMetaObject::className() const () from /usr/lib/libQt5Core.so.5 (gdb) c Continuing. *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 7ffff6060e00 Catchpoint 1 (signal SIGSEGV), 0x00007fffbfbab393 in ?? () from /usr/lib/libQt5Widgets.so.5 (gdb) c Continuing. *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 Catchpoint 1 (signal SIGSEGV), 0x00007ffff59b8913 in ?? () from /usr/lib/libQtGui.so.4 (gdb) c Continuing. *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 [Inferior 1 (process 23594) exited with code 01] (gdb) |
You are linking with a library that depends on Qt5. This won't work. |
This was caused by linking FreeCAD against vtk with one of its componnets linked against Qt5. To fix this FreeCAD now defines a certain set of vtk components. |
| 2016-07-25 09:42 | ilyxa | New Issue | |
| 2016-07-25 09:46 | ilyxa | Note Added: 0007215 | |
| 2016-07-28 17:34 | wmayer | Note Added: 0007222 | |
| 2017-01-09 14:52 | wmayer | Note Added: 0007577 | |
| 2017-01-09 14:52 | wmayer | Status | new => closed |
| 2017-01-09 14:52 | wmayer | Resolution | open => fixed |
| 2017-01-09 14:52 | wmayer | Fixed in Version | => 0.17 |
