| 0002643 | Arch | Feature | public | 2016-07-27 00:33 | 2016-08-29 22:26 |
| Summary | 0002643: Redesign the Arch Schedule tool | ||||
| Description | The arch schedule should not be as restrained as the current implementation but should become much more adaptive to all kinds of scenarios and particular projects and should concentrate on performing a series of simple tasks to extract quantity information from objects. Implement a series of "gatherings". Each gathering occupies one line in a spreadsheet. Each gathering has: - a description text - an action: count, or read a certain property, for ex. obj.Label or obj.Shape.Volume - a list of objects or groups to apply the action to - a filter to apply to the list of objects, to consider only objects of a certain type - a unit to express the result of the action The result will be a spreadsheet with three columns: description, unit and quantity. The aim is to be able to construct a quantity schedule in another spreadsheet app, and simply copy/paste the quantity column from FreeCAD. It should also be possible to import the above data from a csv file. | ||||
| 2016-07-27 00:33 | yorik | New Issue | |
| 2016-07-27 00:33 | yorik | Status | new => assigned |
| 2016-07-27 00:33 | yorik | Assigned To | => yorik |
| 2016-07-27 00:33 | yorik | Project | FreeCAD => Arch |
| 2016-08-29 22:26 | yorik | Changeset attached | => FreeCAD Master master 0d25df0c |
| 2016-08-29 22:26 | yorik | Status | assigned => closed |
| 2016-08-29 22:26 | yorik | Resolution | open => fixed |
