| 0000265 | FreeCAD | Feature | public | 2011-02-12 20:35 | 2011-02-13 13:19 |
| Reporter | unauthenticated | Assigned To | yorik | ||
| Summary | 0000265: Move the "Copy" check box to another place | ||||
| Description | The same as the feature request 0000262 but this time it's the "Copy" check box for the "move" and "rotate" function. So one can select if a copy is generated or not after pressing the move/rotate button. (if you haven't selected something before clicking on the move/rotate button the "Copy" check box will appear after you select something) | ||||
| 2011-02-12 20:35 | unauthenticated | New Issue | |
| 2011-02-13 13:17 | yorik | Status | new => assigned |
| 2011-02-13 13:17 | yorik | Assigned To | => yorik |
| 2011-02-13 13:19 | yorik | Note Added: 0000611 | |
| 2011-02-13 13:19 | yorik | Status | assigned => closed |
| 2011-02-13 13:19 | yorik | Resolution | open => fixed |
| 2011-02-13 13:19 | yorik | Fixed in Version | => 0.12 |
