0002655FreeCADBugpublic2016-08-05 08:58
Reportertrampas Assigned To
PrioritynormalSeveritytweakReproducibilityalways
PlatformWindows 10
Product Version0.16
Fixed in Version0.16
Summary0002655: 0.17.8046 Color of part not working
DescriptionI was not able to set color of a part in 0.17.
It is also confusing as that the dialog say "Set color per face" where I was expecting setting the color of the part as whole.
Additionally I personally think it might be nicer if the color is a Property of the part, like the Label and Placement are properties of the part.
Steps To Reproduceright click on part and select "set color"
2016-08-05 08:58
administrator   ~0007240
And exactly there you will find it. The property editor is divided into two parts View and Data and in the View section there is the property Shape color to set the overall color of an object.
2016-08-04 11:58 trampas New Issue
2016-08-05 08:58 wmayer Note Added: 0007240
2016-08-05 08:58 wmayer Status new => closed
2016-08-05 08:58 wmayer Resolution open => no change required
2016-08-05 08:58 wmayer Fixed in Version => 0.16
