| 0002661 | Arch | Feature | public | 2016-08-07 15:14 | 2016-08-24 13:25 |
| Summary | 0002661: Tube object | ||||
| Description | A tube object that can be used for hidraulic and electric design: - be able to draw only wires, or use existing wires - 99% of these tubes will be aligned with x,y or z axes - be able to specify a profile (circle or rectangle) + dimensions - be able to represent as wire, as cylinder or as full tube (hollow) - be able to give a corner radius - be able to add different kinds of fixtures and apparatus along the way | ||||
FreeCAD: master 4c904107 2016-08-24 15:24:31 Details Diff |
Arch: Tube tools - fixes 0002661 |
Affected Issues 0002661 |
| mod - src/Mod/Arch/Arch.py | Diff File | ||
| mod - src/Mod/Arch/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Arch/InitGui.py | Diff File | ||
| mod - src/Mod/Arch/Resources/Arch.qrc | Diff File | ||
| add - src/Mod/Arch/Resources/icons/Arch_Pipe.svg | Diff File | ||
| add - src/Mod/Arch/Resources/icons/Arch_PipeConnector.svg | Diff File | ||
| add - src/Mod/Arch/Resources/icons/Arch_Pipe_Tree.svg | Diff File | ||
| mod - src/Mod/Arch/Resources/ui/preferences-archdefaults.ui | Diff File | ||
FreeCAD: master 9fbd71af 2016-08-24 15:25:29 Details Diff |
Arch: Forgot a file in last commit - issue 0002661 |
| add - src/Mod/Arch/ArchPipe.py | Diff File | ||
| 2016-08-07 15:14 | yorik | New Issue | |
| 2016-08-07 15:14 | yorik | Status | new => assigned |
| 2016-08-07 15:14 | yorik | Assigned To | => yorik |
| 2016-08-07 15:15 | yorik | Project | FreeCAD => Arch |
| 2016-08-24 13:24 | yorik | Changeset attached | => FreeCAD Master master 4c904107 |
| 2016-08-24 13:24 | yorik | Status | assigned => closed |
| 2016-08-24 13:24 | yorik | Resolution | open => fixed |
| 2016-08-24 13:25 | yorik | Changeset attached | => FreeCAD Master master 9fbd71af |
