| 0002668 | PartDesign | Bug | public | 2016-08-12 06:07 | 2016-08-17 15:34 |
| Reporter | john.gibbe | Assigned To | |||
| Platform | Linux | OS | Mageia | OS Version | Mageia5-X84_64 |
| Summary | 0002668: Linear Pattern - Base object is only displayed, replicated objects are not shown | ||||
| Description | When using Linear Pattern, only the base object is displayed. The replicated objects that you can see in editing mode disappear when the pattern is validated. They are not visible. | ||||
| Steps To Reproduce | create a body inside the body create a sketch form that sketch create a pad from that pad create a linear pattern | ||||
| Additional Information | OS: "Mageia 5" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8186 (Git) Build type: Unknown Branch: master Hash: 137c951e7b397edf369300f6214b1a820f45742b Python version: 2.7.9 Qt version: 4.8.6 Coin version: 3.1.3 OCC version: 6.7.0 | ||||
Transformation tools cannot be used to pattern a body, they are designed to pattern a feature that lies on the body itself. Please look at the documentation. http://www.freecadweb.org/wiki/index.php?title=PartDesign_LinearPattern If you want to pattern solids, use Draft Array. Next time please read the bug reporting guidelines. http://forum.freecadweb.org/viewtopic.php?f=3&t=5236 |
Invalid bug report due to wrong usage of the command. |
| 2016-08-12 06:07 | john.gibbe | New Issue | |
| 2016-08-14 20:02 | normandc | Note Added: 0007271 | |
| 2016-08-17 15:34 | wmayer | Note Added: 0007281 | |
| 2016-08-17 15:34 | wmayer | Status | new => closed |
| 2016-08-17 15:34 | wmayer | Resolution | open => not fixable |
| 2016-08-17 15:34 | wmayer | Fixed in Version | => 0.17 |
